Patrick_S Samba Member
Joined: June 23, 2016 Posts: 60 Location: The Netherlands
Posted: Sat Feb 04, 2017 5:56 pm Post subject: Master Cylinder bleeding question |
I am planning to completely replace all the brake lines and also the master cylinder on my Super Beetle 1303. The master cylinder is leaking and at least one brake line is pitted from rust, the brakes still work perfectly fine though. But this is the first time I have ever worked on the brakes of a car. I have done a good bit of research by now, but there is one part I do not know how to do properly, the bleeding of the Master Cylinder. I came across this awesomely easy way of doing it.
Rob and Dave's website have a similar idea, http://www.vw-resource.com/alternate.html
I assume this is a good way of bleeding the MC, assuming I am going to do it slowly and keep pushing till no more bubbles rise to the surface. But I have one big question now. After I have bled the MC in this bath of brake fluid, how am I supposed to move the MC towards the car, and how must I screw on the new, and empty, brake lines? My MC did not came with any plugs or a kit to bleed the brakes. It only has the switches and reservoir tubes screwed in. The holes for the brake lines are open. Do I need to plug the brake line holes before taking of the MC from the bath? If so, I was thinking of buying a set of these Brake Line Fittings. and finding a creative way of plugging those. What do you people think? And then secondly, fitting the new empty brake lines after the MC has been installed. How do I do this? Can I just let brake fluid leak out of the MC or must the brake line holes be plugged as long as possible??
Can anyone point me in the right direction for this? |
Mudpump Samba Member
Posted: Sat Feb 04, 2017 6:57 pm Post subject: Re: Master Cylinder bleeding question |
| Which is one reason I'll bet most people never bleed the master on it's own. After install, they bleed the whole system. |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3542 Location: Pennsylvania
Posted: Sat Feb 04, 2017 7:00 pm Post subject: Re: Master Cylinder bleeding question |
| I replaced 2 master cylinders and didn't bench bleed either of them. Both work fine. I never had to bench bleed countless race car MC's either. |
birddog1 Samba Member
Posted: Sat Feb 04, 2017 7:10 pm Post subject: Re: Master Cylinder bleeding question |
I done many master installs, never bench bleeding the master.
It's one of those funny urban legend things. If someone was shown that method on their first and it worked, they'll swear up and down you need to bench bleed. While everyone else just puts it on the car and bleeds the system. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11807 Location: Redding, CA
Posted: Sat Feb 04, 2017 7:57 pm Post subject: Re: Master Cylinder bleeding question |
I replaced the master cylinder on my 1974 Super Beetle (1303), using an ATE master. I did not bleed it before installation.
There is no way to transfer a messy master cylinder over to the car, attach hoses and brake lines to it, and expect there to be no air in the system, anyway.
This is what I did, after installing the new master, the soft and hard brake lines, as well as replacing new, blue brake line from the reservoir to the master--and the front drums with a disc conversion:
I installed all the parts, then filled the brake-fluid reservoir. After that, I filled a clear jar a few inches from the bottom and attached a clear plastic hose to the front right bleeder bolt. I then opened the bleeder and let that wheel gravity bleed for a good fifteen minutes.
Keep filling the reservoir throughout this procedure. Dont let it go dry!
After most of the bubbles stop going through the tube, tighten the bleeder bolt and repeat this gravity-bleeding process on the front left.
Repeat again on the rear right, then the rear left.
Because you have a dual-circuit master cylinder, you start your bleeds at the front--not the rear.
After gravity bleeding all wheels, do your final bleeds. This time, however, you start at the fronts, then do the rears, using an assistant to pump each wheel a few times, then press and hold the brake pedal as you open the bleed bolts. When you see no more bubbles, go to the next wheel.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Zundfolge1432  Samba Member
Posted: Sat Feb 04, 2017 8:13 pm Post subject: Re: Master Cylinder bleeding question |
| We never had to bench bleed them either and I started doing brake jobs on VWs in 1979. Some of the mechanics I've known over the years were trained by VW at the dealerships and they never had to bench bleed anything either. By design most other master cylinders, especially americans have a reservoir that's cast in so you can chuck it into a vice and run small hoses from the line connection back to the reservoir. You could do this to the older bus master cylinder because its made this way too. I see it mentioned so often now but other than being unnecessary it probably wouldn't hurt anything. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33419 Location: Hot Arizona
Posted: Sat Feb 04, 2017 8:59 pm Post subject: Re: Master Cylinder bleeding question |
In the fall, I replaced 4 wheel cylinders, the master cylinder, and 4 flexible brake lines in my 1970 VW which had been sitting unused for 23 years and had no fluid left in the system.
I DID bench-bleed the master cylinder before installing.
The 1970 now has firm brakes.
I always bench-bleed clutch masters and brake masters. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Patty B. Samba Member
Joined: July 14, 2005 Posts: 2181 Location: Brampton, Ontario, Canada
Posted: Sat Feb 04, 2017 11:51 pm Post subject: Re: Master Cylinder bleeding question |
| My mechanic had a novel idea--my new MC came with clear plugs in the holes. He used a large diameter medical seringe. Filled it with brake fluid and punctured the plastic plug and filled it up then installed. I'm sure you could do the same with a hobby or glue applicator like plastic seringe, install your MC then 'surgically' fill it up. |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2336 Location: Cleveland, OH
Posted: Sun Feb 05, 2017 6:13 am Post subject: Re: Master Cylinder bleeding question |
I've replaced 6 acvw master cylinders over the last 6-7 years, not once did I bench bleed them. I have also replaced 15-20 ABS pumps and 4-5 master cylinders for my daily job and same, not once did I bleed before install.
For the last VW I did I also replaced the hoses and wheel cylinders (I'm about to do so in my personal car this week) and this is what I did. I installed all the components and just opened up all four bleeder screws at the same time while placing some cardboard pieces and rags under each corner. I filled the reservoir to the top and went back in the house for a beer.
After the brew, I went back to the garage and filled the reservoir again. And had myself another frosty one since I deserved it. By the time I came back all four corners were "pouring" brake fluid so I closed all four bleeders, pumped the brake pedal and did a final bleed front to back using the one person method.
For the one person method, you need a clear bottle and about a 2ft of clear hose that fits unggly over the bleeders. You drill a hole on the bottle cap for the hose to fit snuggly. You push the hose all the way down and add brake fluid to the bottle to cover the hose and a bit past. Install the cap and now you have a one person bleeder.
What this does is not let air back into the system. So you attach the hose to an opened bleeder screw, fill the reservoir and slowly press the brake pedal a few times. There is no way for air to get into the system, so once you don't see bubbles on the hose, you're done. Move onto the next. _________________ 1971 Super - Sold
1984 Puma GTC - Sold
1971 Campmobile |
Posted: Sun Feb 05, 2017 6:49 am Post subject: Re: Master Cylinder bleeding question |
1971 Campmobile |
ldj1002 Samba Member
Posted: Sun Feb 05, 2017 7:12 am Post subject: Re: Master Cylinder bleeding question |
| Why bleed front first? Front and back are completely separate. |
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 687 Location: SE Oklahoma
Posted: Sun Feb 05, 2017 7:43 am Post subject: Re: Master Cylinder bleeding question |
I've replaced several master cylinders over the years without bleeding them.
I'm currently fighting with my '63's brakes. Replaced all shoes, mc, wheel cylinders, soft lines and metal lines and a couple of drums. I'm still getting no pedal after hours of adjusting and bleeding. So now I'm at a point where I'm thinking maybe sometimes that mc has to be bleed after all.
I like Rick Higgins' technique: he bleeds the cylinder after it's been installed by opening the metal lines at each port while a helper pumps the brake pedal (same as the procedure at the wheel cylinders).
http://www.bugmevideo.com/volume4.html _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
Posted: Sun Feb 05, 2017 11:15 am Post subject: Re: Master Cylinder bleeding question |
Go straight to the Bentley manual and what do you find? That's right no mention of bench bleeding anything. VW used the two man method whereby you have some poor sap in the car pumping the pedal while the other guy opens the bleeders and you'll see there is a difference in procedure between single circuit and dual. You'll also get a mention on using brake paste when rebuilding components. If you rebuilt something and used it within a few days you can build by using brake fluid as well. Follow the directions in the Bentley and you won't have a problem. Many years ago I was that sap in the car and it was on a lift, believe me in the summertime the temp was hotter up there and I couldn't wait to get the job done and get back on the ground.
Cusser Samba Member
Posted: Sun Feb 05, 2017 2:08 pm Post subject: Re: Master Cylinder bleeding question |
I've purchased clutch masters and brake masters for other vehicles which had instructions inside the box stating to bench-bleed them before installing.
Believe me, the technology is quite similar from vehicle to vehicle. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Feb 06, 2017 7:16 am Post subject: Re: Master Cylinder bleeding question |
I thought by posting the manual reference it would help, but to compare other makes and models of autos is a stretch bottom line if it helps you to sleep better go ahead and bleed per your Ford truck manual,it won't hurt anything.
Since we are stretching I'll tell you this. During part of my career I worked in a hydraulic component rebuild shop, we did all types of actuators, landing gear,flight control,snubbers etc. we used a fluid called skydrol and assembley paste to build em up. Next each part went to a test cell where a working pressure of 3000 psi was applied to extend and retract several cycles. The components were then drained cleaned externally,bagged and shipped ready to be installed on the aircraft wherever that might be in the world. All those parts are bled after installation and that means exactly nothing compared to working on VWs. |
Cusser Samba Member
Posted: Wed Feb 08, 2017 10:34 am Post subject: Re: Master Cylinder bleeding question |
| Cusser wrote: |
Believe me, the technology is quite similar from vehicle to vehicle. |
Was filing VW receipts, came upon the instructions from the last master cylinder I installed into my 1971 Super. Instructions DID say to bench bleed the MC before installing, even stated that warranty would be voided if MC was not bench-bled before installing.
For the record, that master cylinder was a warranty replacement rebuilt MC from Autozone in Aug. 2003; it was a free replacement for the rebuilt MC I purchased from them in Jan. 1994, why I stayed with Autozone MC. I know: the "scoop" here on such rebuilts is quite bad but the first one (before I had computer or knew about TheSamba) lasted 9.5 years, and the replacement one is 13.5 years old now. Makes me wonder if if folks who have troubles and short lives with these are doing something "off" in the install, not flushing out all the old fluid, whatever.
For the record: for my 1970 VW resurrection after 23 years sitting, I brought a new Brazilian MC for it last fall, not the double-in-price German one. Yes, I bench bled that one, seems to be working fine. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Feb 08, 2017 12:53 pm Post subject: Re: Master Cylinder bleeding question |
| Uncle |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Wed Feb 08, 2017 2:47 pm Post subject: Re: Master Cylinder bleeding question |
| Zundfolge1432 wrote: |
| Uncle |
 _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
| tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
| sb001 wrote: |
maybe he just snapped cause his car sucked  |
wcfvw69 Samba Purist
Posted: Wed Feb 08, 2017 4:10 pm Post subject: Re: Master Cylinder bleeding question |
I certainly don't understand why the need to bench bleed a VW master cylinder. In 35 years of VW ownerships, I've never bench bleed one. The last one I bought was a "German" one from Wolfsburg West. I bleed it with a hand pump pressure bleeder. Once the air was out and the brakes were adjusted correctly, I had a HARD brake pedal that was perfect.  _________________ Contact me at [email protected]
The Samba member since 2004.
Cusser Samba Member
Posted: Wed Feb 08, 2017 4:51 pm Post subject: Re: Master Cylinder bleeding question |
| wcfvw69 wrote: |
I certainly don't understand why the need to bench bleed a VW master cylinder. In 35 years of VW ownerships, I've never bench bleed one. The last one I bought was a "German" one from Wolfsburg West. I bleed it with a hand pump pressure bleeder. Once the air was out and the brakes were adjusted correctly, I had a HARD brake pedal that was perfect.  |
I've never had an issue installing and bleeding ANY master cylinder, why I'll stay with what has worked for me.
Do a Search: I've never had a topic where I asked for bleeding help. In fact, on my 1970 VW resurrection, I did the gravity bleed just because I felt that I wanted to try that, then followed with traditional bleeding.
And I'm not fearful of adjusting a brake pushrod if one really needs that due to varying recess depth in a master cylinder. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
