Rear hub nut
blacksc
blacksc is offline
PostPosted: Thu Jun 01, 2017 7:04 pm    Post subject: Rear hub nut Reply with quote
Ok guys have now broken 3 - 1/2" extensions trying to remove these nuts. I have also tried a pencil torch to heat them up and nothing. What else can I do?
panicman
panicman is offline
PostPosted: Thu Jun 01, 2017 7:20 pm    Post subject: Re: Rear hub nut Reply with quote
You'll need a breaker bar or the special axle nut removal tool.
Someone will probably post a picture of one, or you can search the Internet or gallery here.
I usually have good luck with a 2 foot or so cheater on a wrench.
blacksc
blacksc is offline
PostPosted: Thu Jun 01, 2017 7:49 pm    Post subject: Re: Rear hub nut Reply with quote
Ya I have been using a 4ft bar and standing on it. I did just notice that torque multiplier for VW on ebay. CiP is currently out of stock.
sjbartnik
sjbartnik is offline
PostPosted: Fri Jun 02, 2017 6:54 am    Post subject: Re: Rear hub nut Reply with quote
The torque multiplier tool is the best $100 you'll ever spend.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
blacksc
blacksc is offline
PostPosted: Fri Jun 02, 2017 7:15 am    Post subject: Re: Rear hub nut Reply with quote
Yes I think I will buy one. Its for my dune buggy and I plan on keeping it a long time so it should be a good investment.
Tim Donahoe
Tim Donahoe is offline
PostPosted: Fri Jun 02, 2017 9:45 am    Post subject: Re: Rear hub nut Reply with quote
You can also go down to Sears and buy a 3/4 inch drive breaker bar--the kind with the sliding head. Also, buy the 1&7/16 socket to match.
Put your four-foot cheater on it and go for it.
The 1/2 inch is simply too small.
Tim
Let's do the Time Warp again!
Richard O'Brien
bluebug66
bluebug66 is offline
PostPosted: Fri Jun 02, 2017 2:46 pm    Post subject: Re: Rear hub nut Reply with quote
The Torque Meister tool is amazing and worth every penny. Completely effortless to remove and install high torque axle nuts and gland nuts.
