rmallory Samba Member
Joined: January 31, 2017 Posts: 16 Location: Nashville
Posted: Wed Jun 21, 2017 11:55 am Post subject: Rear air scoop covers? |
I'm converting my 1969 bay window bus to electric power, and I need to seal the engine bay in order to keep it relatively dry. I've seen a few examples of people making their own rear air scoop covers. Does anyone make and sell scoop covers off the shelf, or are these always custom made? Any thoughts or suggestions appreciated. Cheers |
Xevin  Samba Member
Posted: Wed Jun 21, 2017 12:23 pm Post subject: Re: Rear air scoop covers? |
IMHO. I would think if the bottom of the engine compartment was buttoned up proper. No need to cover scoops.
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin...  |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Wed Jun 21, 2017 12:46 pm Post subject: Re: Rear air scoop covers? |
Xevin wrote: |
IMHO. I would think if the bottom of the engine compartment was buttoned up proper. No need to cover scoops. |
Interesting. I've got the bottom of the compartment covered pretty well. Not completely water tight, but definitely good enough for my purposes.
It seems like in a heavy rain, water would just pour into these scoops. Is that not the case? Thanks |
Xevin  Samba Member
Posted: Wed Jun 21, 2017 12:57 pm Post subject: Re: Rear air scoop covers? |
Was designed not to soak the engine compartment and would drain away. If you modified the design with the motor you are using. Might be different story.
However, a lot of moisture from the bottom accumulates if not sealed proper. VW wanted to keep road air out and for sure moisture from corroding the engine bay. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17615 Location: San Diego, California
Posted: Wed Jun 21, 2017 2:11 pm Post subject: Re: Rear air scoop covers? |
The thing about that video and covering the air scoops is... am I wrong or isn't an engine pretty much an air pump? Block off the air and it's going to choke the engine. An electric conversion would be different of course. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Wed Jun 21, 2017 2:33 pm Post subject: Re: Rear air scoop covers? |
Xevin wrote: |
Was designed not to soak the engine compartment and would drain away. If you modified the design with the motor you are using. Might be different story. |
I have modified the interior of the engine compartment. There aren't any obvious drain channels they way I have it setup now.
I think I'm going to want to cover /seal the scoops eventually. |
Xevin  Samba Member
Posted: Wed Jun 21, 2017 3:01 pm Post subject: Re: Rear air scoop covers? |
I agree Aeromech, I was thinking the same thing. And OP. I wouldn't be in a hurry to cover. Wait for some rain and see what happens. Aesthetically I think it would look better with scoops exposed (I know not my bus). Maybe you could use some clear durable Lexan 9034 or similar so it keeps the look. I want pictures of the motor set up. Sounds interesting. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Wed Jun 21, 2017 3:40 pm Post subject: Re: Rear air scoop covers? |
Xevin wrote: |
I agree Aeromech, I was thinking the same thing. And OP. I wouldn't be in a hurry to cover. Wait for some rain and see what happens. Aesthetically I think it would look better with scoops exposed (I know not my bus). Maybe you could use some clear durable Lexan 9034 or similar so it keeps the look. I want pictures of the motor set up. Sounds interesting. |
Yeah that's good idea. I'll wait and see how it does in the rain first. Thanks for the help everyone |
chimneyfish Samba Member
Joined: July 28, 2009 Posts: 881 Location: United Kingdom
Posted: Wed Jun 21, 2017 3:42 pm Post subject: Re: Rear air scoop covers? |
If you can track down a pair of these, they are the real deal:
ratwell wrote: |
8.15 Winter operation:
If it snows heavily where you live you may want to get a pair of these:
They were sold by the dealer (000 091 232) but you can still find them on eBay for about $40. Made in Germany and they fit 73-79 models.
http://www.ratwell.com/technical/FAQ.html
https://www.type2.com/lists/type2/oldarchive/message/536675 _________________ 1965 Type 1 Deluxe (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury) |
Posted: Wed Jun 21, 2017 3:49 pm Post subject: Re: Rear air scoop covers? |
You could probably make a baffle that would sit inside the scoop and redirect most of the water, it could channel the water out the bottom louver or pipe it through the floor somehow. |
