sphet Samba Member
Joined: November 09, 2016 Posts: 342 Location: Vancouver, BC
Posted: Tue Apr 10, 2018 10:05 pm Post subject: Newer, larger kitchen drawer in older van? |
I am envious of the larger drawers on the later westfalias. Has anyone attempted to retrofit this into an older van? I'm thinking of trying to build up a drawer myself from scratch since I am tired of not having enough knife storage. _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
jimf909  Samba Member
Posted: Tue Apr 10, 2018 11:39 pm Post subject: Re: Newer, larger kitchen drawer in older van? |
What model years are these earlier and later vans that you’re referring to? My 85 and 90 both have u-shaped drawers that are not large or awesome.
For knife storage, I sure do like a magnetic knife holder screwed to the hinged lid above the stove/sink. Mine holds theee knives, a bottle opener and another thing or two (sorry, no pics at this time). _________________ - Jim
Abscate wrote: |
Current: 1990 Westy Camper - Bostig RG4, 2wd, manual trans w/Peloquin, NAHT high-top, Flash Silver, seam rust, bondo, etc., etc.
sphet Samba Member
Posted: Tue Apr 10, 2018 11:43 pm Post subject: Re: Newer, larger kitchen drawer in older van? |
jimf909 wrote: |
For knife storage, I sure do like a magnetic knife holder screwed to the hinged lud above the stove/sink. Mine holds theee knives, a bottle opener and another thing or two (sorry, no pics at this time). |
I've got an 82 and its a tiny rectangle that holds two sets of cutlery and a knife. It's ridiculous. I suspect it changed in 85. _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
Posted: Tue Apr 10, 2018 11:50 pm Post subject: Re: Newer, larger kitchen drawer in older van? |
Ive also seen magnetic knife holders on the inside of the cabinet door below the sink. I think part of the solution is going beyond that drawer because it's constrained by the sink/drain.
FWIW, YMMV. _________________ - Jim
Abscate wrote: |
kamzcab86 Samba Moderator
Posted: Wed Apr 11, 2018 12:21 am Post subject: Re: Newer, larger kitchen drawer in older van? |
sphet wrote: |
I've got an 82 and its a tiny rectangle that holds two sets of cutlery and a knife. It's ridiculous. I suspect it changed in 85. |
Edit: Nevermind. Just learned that the early drawers are not U-shaped, like the later drawers. _________________ ~Kamz
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
82westyrabbit Samba Member
Posted: Wed Apr 11, 2018 4:30 am Post subject: Re: Newer, larger kitchen drawer in older van? |
My 82 westy has the smaller drawer with out the legs going back. Gowesty has the larger drawers for sale. I think the drawers are the same width and you could modify it to fit. I have not done it myself but I am shore some one will chime in who has. You might have to modify the sink drain. Good luck |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 15730 Location: Retired South Florida
Posted: Wed Apr 11, 2018 4:50 am Post subject: Re: Newer, larger kitchen drawer in older van? |
I swapped out the drawer on our 82. The longer drawer just slid in. No modifications required. _________________ ☮️ |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 14847 Location: Syracuse, NY
Posted: Wed Apr 11, 2018 6:21 am Post subject: Re: Newer, larger kitchen drawer in older van? |
modify the stove face with a knife drawer
from this thread https://www.thesamba.com/vw/forum/viewtopic.php?t=507102
juanb wrote: |
With the prospect of spending a year in the van, I'm in the mindset of using every available bit of space.
The following is is an idea that I've had for a while, and finally this weekend was able to make it happen. I thought about this while looking at the very helpful disassembly pictures that davideric9 posted to this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=334649
If you look at the area left of the burners, there is some empty space in there:
The back of it is ventilation for the fridge, but we're not going to go so far that it matters.
The first thing I did, because I know my craftmanship can be laughably bad, was to procure an extra stove front plate. I got it from the classifieds, I think it was $25 or so:
Then I marked how far I wanted to go, and attacked it with a jigsaw:
My strategy is usually "measure once, cut three times". Make sure to never hire me for anything that doesn't have an undo button
I went to Home Depot, and after a couple of hours of looking of inspiration, I settled on this thing, it's a roof gutter of some sort. What mattered to me was that it is metal, it has a 90 degree bend alongside, and one of the sides is about 2 inches tall:
By making cuts on the longer side and bending it I built this box, which is about 12"x4":
Not pictured here, but I epoxyed it in place, and left it clamped overnight.
I made a wooden front, which I sanded until it fit snugly in the stove front. Here they are, pictured in my paint booth:
After a couple of coats. I painted the table legs as well.
When the paint was dry, I attached the front to the drawer using a handle that screws from behind, and then lined the drawer with some black rubber material so the stuff inside doesn't rattle too much. I also put some of that low friction tape that I used on the slider door, on the bottom and edges of the drawer.
Voila, a new cutlery drawer:
Now I can use the main drawer under the sink for other stuff. I'm not too worried about heat, this is relatively far from the flame, separated by two layers of metal, plus my drawer itself is metal. So I should be ok.
The paint I used was Rustoleum Satin Granite, it is here if you scroll down a bit:
http://painting123.com/ProductInfo.asp?p2=I7
It's a bit darker than stock, but I don't mind it. My bad craftmanship shows a little bit, but it isn't too bad. And when compared to my stock stove plate, it is a noticeable improvement. The old plate had that greenish grey color that most original westy stoves have by now.
Here it is closed:
Abscate wrote: |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9593 Location: Mt Lemmon, AZ
Posted: Wed Apr 11, 2018 6:41 am Post subject: Re: Newer, larger kitchen drawer in older van? |
sphet wrote: |
...I suspect it changed in 85. |
My 84 has the later drawer - possibly the change coincided with the WBX at 83½. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3387 Location: VA/TN
Posted: Wed Apr 11, 2018 6:54 am Post subject: Re: Newer, larger kitchen drawer in older van? |
Ahwahnee wrote: |
sphet wrote: |
83½ here, I have short drawer. I would swap - but imagine how much a good, used brown drawer is going to cost. _________________ Brandon
'83.5 Westfalia "Jo Ann" EJ22e w/Peloquin
150aH LiFePo4, 330w solar, diesel heater
DM me on IG for quicker responses @brandon.r2 |
SCM Samba Member
Joined: January 26, 2011 Posts: 2957 Location: Bozeman MT
Posted: Wed Apr 11, 2018 8:10 am Post subject: Re: Newer, larger kitchen drawer in older van? |
If I was in the OP's shoes I'd be looking for one of the later model drawers too. But here's another idea for knife storage. Super easy to build if you have a table saw with a dado blade.
_________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
sphet Samba Member
Posted: Mon Jun 18, 2018 11:10 am Post subject: Re: Newer, larger kitchen drawer in older van? |
I thought I would wrap up this post with my findings. I was able to buy a later-model drawer that matches the colours of my early van. It slid in just fine but the latch did not work. I measured it a bit and the latch is installed an 1/8 of an inch higher on the new drawer. There is also a noticeable recess in the rubber trim on the old one. I ended up cutting back the trim on the new drawer to match the old, and unscrewed, slightly bent and then re-installed the metal catch to make up the 1/8 of an inch. It's almost perfect but then the old drawer was always a bit finnicky anyways. My one thought is that I expect the slides installed on the inside of the cabinet probably extend back much farther in the late vans -- but since i store my anvils in the luggage rack and not in my cutlery drawer I doubt this will be a problem.
Comparison of the two styles -- look at that extra space for losing things!
The new later-model drawer
The earlier one with the recess cut into it.
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 914 Location: Calgary, Canada
Posted: Mon Jun 18, 2018 12:35 pm Post subject: Re: Newer, larger kitchen drawer in older van? |
By modifying the sink drain to a smaller elbow, that "U" can be avoided. Photos of the back of the drawer here, down near the end:
http://www.griffco.ca/interest/vw/vwshower.htm _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
81 Westy Samba Member
Joined: April 16, 2022 Posts: 1 Location: Saskatchewan
Posted: Sat Apr 16, 2022 11:52 pm Post subject: Re: Newer, larger kitchen drawer in older van? |
I am hoping to build the U shaped drawer to replace my '81 tiny drawer. Any chance you could send me the dimensions on the U shaped drawer to facilitate or ease my project?
Much Appreciated!!!
Ron |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 2535 Location: ABQ NM USA.... Except when not
Posted: Sun Apr 17, 2022 11:33 am Post subject: Re: Newer, larger kitchen drawer in older van? |
Link did not work. I think it's this one
http://www.griffco.ca/VW/vwshower.htm
Keep in mind that they don't use the sink and three sprayer comes up through the drain. A similar solution for the drain could be created. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
VeeDubn Samba Member
Joined: May 31, 2019 Posts: 72 Location: Olympia, Washington
Posted: Sun Apr 17, 2022 1:45 pm Post subject: Re: Newer, larger kitchen drawer in older van? |
1980 Westy - we modified our silverware drawer; added drawer slides too.
Pchill2 Samba Member
Joined: November 19, 2021 Posts: 280 Location: Georgia
Posted: Mon Apr 18, 2022 9:14 am Post subject: Re: Newer, larger kitchen drawer in older van? |
Any other pictures of your interior? I'm intrigued... _________________ 87 Syncro Westy
Honda K24 swap |
Posted: Mon Apr 18, 2022 8:43 pm Post subject: Re: Newer, larger kitchen drawer in older van? |
Pchill2 - Additional pictures of our interior . . .
Posted: Tue Apr 19, 2022 5:26 am Post subject: Re: Newer, larger kitchen drawer in older van? |
Love it!
PM'd you (I don't want to railroad this thread with questions) _________________ 87 Syncro Westy
Honda K24 swap |
Posted: Tue Apr 19, 2022 7:27 am Post subject: Re: Newer, larger kitchen drawer in older van? |
Thank you Vanis13 for updating my old link. I tried to edit that post, but was a long way too late!  _________________ '88 VW Westfalia
