Strange noise coming from 99 EV near throttle body when off?
piotr.wor
piotr.wor is offline
PostPosted: Fri Jul 02, 2021 5:28 pm    Post subject: Strange noise coming from 99 EV near throttle body when off? Reply with quote
Ok so this is a strange one. I have a CEL and some misfiring going on when its raining and when i parked the car and turned it off and removed the key I thought i heard the fans turning on. Well the fans are not on. The van has been now sitting for about 8 hours, is cold, and every 10 min something is turning on near the throttle body for about 2 mins and then turns off. Its sounds like some sort of pump or fan internally.
Does anyone have any idea?
Totally stumped on this one.
Thanks
Abscate
Abscate is offline
PostPosted: Fri Jul 02, 2021 7:00 pm    Post subject: Re: Strange noise coming from 99 EV near throttle body when off? Reply with quote
It could be evap system testing or the after run coolant pump
piotr.wor
PostPosted: Fri Jul 02, 2021 7:07 pm    Post subject: Re: Strange noise coming from 99 EV near throttle body when off? Reply with quote
After run coolant pump makes sense after reading about it. Thanks for the tip, Any idea what to do before it drains my battery?
Abscate
Abscate is offline
PostPosted: Fri Jul 02, 2021 11:20 pm    Post subject: Re: Strange noise coming from 99 EV near throttle body when off? Reply with quote
Pull the Plug off it for now. If you drive it on the highway, idle it for a minute after a run to perform the cool down function. If itโ€™s just used in the city, no worries
piotr.wor
PostPosted: Sat Jul 03, 2021 3:09 am    Post subject: Re: Strange noise coming from 99 EV near throttle body when off? Reply with quote
Thank you!
piotr.wor
PostPosted: Sat Jul 03, 2021 4:23 am    Post subject: Re: Strange noise coming from 99 EV near throttle body when off? Reply with quote
I pulled the plug off the plug by the heater core / firewall and its still running. Its actually running non stop now. Maybe its the Evap testing you mentioned ?I disconnected the battery or now but stumped again.... any ideas?
Abscate
Abscate is offline
PostPosted: Sat Jul 03, 2021 4:40 am    Post subject: Re: Strange noise coming from 99 EV near throttle body when off? Reply with quote
I think thatโ€™s the sensor wire. Try pulling off the plug at the pump
I use a hose to track down the source of noises, put one end in your ear and use it to track down whatโ€™s running.
I think the evap pump is under the car, maybe itโ€™s the air pump?
Are you in the Hudson valley?
piotr.wor
PostPosted: Sat Jul 03, 2021 6:23 am    Post subject: Re: Strange noise coming from 99 EV near throttle body when off? Reply with quote
Thats a great idea. Thank you.
I am. I live in Woodstock.
