slackin' at work Samba Member
Joined: May 07, 2003 Posts: 443 Location: Central Virginia
Posted: Tue Aug 05, 2003 11:50 am Post subject: typical oil temp? |
what is the 'average' oil temp. I always thought it was about 220. But I just went cruising in my ride for the first long-haul (10miles) and the oil temp just kept on going up. finally topped out at about 235.
does this sound terribly high to anyone? Im about to check the plugs to see how its burning. I know it was running lean until I up-ed the idle jets last week. should be good now.
thanks
-chris |
joey-bugnaked.com Samba Member
Joined: January 04, 2003 Posts: 258 Location: the bugnaked mansion
Posted: Tue Aug 05, 2003 3:26 pm Post subject: |
seems a bit hot, what is your engine set-up? _________________ www.bugnaked.com |
Posted: Tue Aug 05, 2003 4:16 pm Post subject: |
its a 1776 with dual 40s. 044 heads, ratio rockers, ss valves, blah, blah.
I did check the plugs and they were a beautiful shade of tan. I don't think Ive EVER owned a vw that was running that ideal. I usually run them on the 'fat' side. I just went out for another cruise and it never went over 220.
the first time it was about 90 out, and now it's a little cooler out.
I think it should be good but I will check my valves in the morning and run it again.
any ideas?
-chris |
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2530 Location: Edmonton, AB
Posted: Tue Aug 05, 2003 7:16 pm Post subject: Do I get burned? |
I judge if mine is too hot by holding the dipstick. If it's too hot to hold, it's running too hot, if I can keep it in my fingers it's ok. I guess it depends on your pain tolerance, but it seems like a decent rule of thumb for a vehicle without a temp. gauge!  |
ACSwede Samba Member
Posted: Wed Aug 06, 2003 4:01 am Post subject: |
| ...agree; it's on the hot side of things!...I'm running a similiar engine set up and when pushing it on a HOT day I reach temps of 200F...on normal days it's dead stable at 185F...check your timing... |
vicsvw Samba Member
Posted: Thu Aug 07, 2003 8:38 am Post subject: |
well, Im at a loss. checked the valves yesterday and they were a bit tight, readjusted those nice-nice. then double checked my timing. Im at 5' at idle and a total of 28' advance on my 009. I believe 28-30 total advance is what you should have.
Damn thing still ran at 230-235. I might pull back on the timing a little and see if that helps. what do you think?
Also, I have a monster Fastboy muffler and header on it. Its my understanding that a too unrestrictive exhaust is as bad as a too restrictive setup. due to the fact that the engine (depending on size) need a certain amount of backpressure to create torque. Im thinking about going down to a quite-pack or dual quite-pack. what cha think of that?
thanks
-chris |
vicsvw Samba Member
4banger Samba Member
Posted: Thu Aug 07, 2003 9:44 pm Post subject: |
run synthetic oil - mobil 1 is my favorite  |
rizzag Now Wut?
Joined: April 19, 2001 Posts: 3135 Location: Keizer, OR
Posted: Thu Aug 07, 2003 9:49 pm Post subject: |
dont forget too, if its a fresh engine it will run hotter too due to the closer tollerances adding friction. _________________ flossin, tossin, dippin, and trippin |
NorCalNick Ain't yo baby daddy
Joined: December 07, 2002 Posts: 1583 Location: San Jose, Ca.
Posted: Fri Aug 08, 2003 4:36 pm Post subject: |
i used to stress out all the time when i had a temp gauge....."OH ITS 221!"
i fuckin tossed that thing. from what ive learned over the years from talking to people and my personal experiances.......you have a 1776 so yes its gonna run a bit hotter. its 90 outside so its going to run hotter..your driveing uphil against a headwind....its going to runhotter...etc etc etc. gradual increases are ok, what you need to worry about is sudden spikes in temp increase or extream temps. every motor is going to run different from one another, ones might be comfortable at 190.....yours might cruise at 210. i suggest NOT to read the Gene Berg catalog on heat. im not saying he is wrong. but if you do you will probably never drive your vw if you go by his temps. ive asked several shop owners on his theory....i received several different answers. so i made up my own mind. if my motor blows, then it was to hot. _________________ When I'm done punching the clock, I start punching the clown. |
