70bus  Samba Member
Posted: Sun Oct 22, 2023 6:07 pm Post subject: Single cab gas sender wire - route? |
I see pics and a great write up for sender wires on DC tanks, but can’t find a clear answer on my 65 s/c.
The replacement metal has no hole drilled for the wire, and there is no obvious place to run the wire through or over the replacement crossmember. Did s/c wires run by the outlet opening as well, or did they go through the engine bay firewall? There is a hole in mine, but I doubt it’s factory…
If VW really did just smoosh the wire between top hat and underside of floor, I can do that... it just seems really tight. Maybe tight is good to hold wire in place?
Schultz ran theirs here
I have no problem drilling holes… just want them in the right place _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raoul the 65 singlecab
Karl the 70 nine-seater |
