jeffros 58 Samba Member
Joined: January 01, 2009 Posts: 366 Location: jackson mi
Posted: Sun Dec 01, 2024 7:46 pm Post subject: Disc brake kit compatibility |
| Quick question can I use a set of empi disc brakes ment for a link pin early beetle on a 1957 single cab ? Understanding that I’ll have to get different size bearing for the bigger spindles on the single and make or get new caliper brackets . Thanks |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4214 Location: San Diego
Posted: Mon Dec 02, 2024 5:34 pm Post subject: Re: Disc brake kit compatibility |
I think you are on your own with this one. Empi does make a disk brake kit for early buses, as do other companies
There are a number of threads here for disk brakes, early and late.
If you had a late bus front end, the Type E kit is the best
https://type-emotorsports.com/collections/type-2-b...-brake-kit |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1883 Location: Warren, PA
Posted: Tue Dec 03, 2024 4:03 am Post subject: Re: Disc brake kit compatibility |
I think if it was a viable option it would have been done a decade ago. Plus it’s a lot of work just to get four lug wheels. But if you pull it off I am sure a lot of people would be interested to see how you figured it out. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
