lets see your favorite feeler gauge
ppilotmike Premium Member
ppilotmike is offline
PostPosted: Tue Jul 08, 2025 9:10 am    Post subject: lets see your favorite feeler gauge Reply with quote
I hate the feeler gauge set I've got, none work good for adjusting valves. So what do you use?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jul 08, 2025 9:42 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
I have chromoly pushrods, so loose zero.
I do have a K/D go/no-go feeler gauge and it's very accurate
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
nogoodwithusernames
nogoodwithusernames is offline
PostPosted: Tue Jul 08, 2025 10:09 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
I have a similar with the angled ends, works well for doing valve adjustments since you can get the small angled part between the rocker arms. No idea what brand, was a hand-me-down from my dad.
71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
(Conversion thread https://www.thesamba.com/vw/forum/viewtopic.php?t=732508&highlight= or https://shoptalkforums.com/viewtopic.php?f=1&t=151375&sid=f0542d44a322d290c29d6609fac7f215 )
74 914, 2.0L w/ D-Jet
-Derek
volky1970
volky1970 is offline
PostPosted: Tue Jul 08, 2025 10:47 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
Hi,
I am at work right now, but like the topic. I have three sets, one being the oldest and my favorite one with .006 in some brass metal which is all crimpled/disfigured from extensive use.
The brass one was replaced with a new set that I had and never opened but when I opened it I couldn't read the numbers, so bought a new set and that is the one I use now waiting for the numbers to vanish.
Glenn: Like your set.
1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors.
Schepp
Schepp is offline
PostPosted: Tue Jul 08, 2025 11:22 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
For valves I've got a single .006" that's 12" long x 1/2" wide. Made by Precision Brand. Never have an issue with reach.
PostPosted: Wed Jul 09, 2025 6:30 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
thanks for all the reply! I enjoy seeing how others do things. Very Happy
Mr. 010
Glenn is offline
PostPosted: Wed Jul 09, 2025 6:36 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
volky1970 wrote:
Hi
It's over 30+ years old and still like new even after doing hundreds of valve adjustments.
The trick is to never let anyone else use it.
I have another one that I will lend if someone needs it.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
NJ John
NJ John is offline
PostPosted: Wed Jul 09, 2025 7:43 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
I want to get one of those single size gages with a handle. Empi and others sell them.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
Mr. 010
Glenn is offline
PostPosted: Wed Jul 09, 2025 7:55 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
daveblank
daveblank is offline
PostPosted: Wed Jul 09, 2025 9:27 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
This set from Snap-On. It has angled, straight, & go/no go. https://shop.snapon.com/product/Feeler-Gauges%2C-Specialty/Feeler-Gauge-Blade-Set-(Green)/FB336GRN
Mr. 010
Glenn is offline
PostPosted: Wed Jul 09, 2025 9:31 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
$122, you forget VW people are cheap.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
chrisflstf
chrisflstf is offline
PostPosted: Wed Jul 09, 2025 9:56 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
Porsche P213 Feeler Gauge
https://www.pelicanparts.com/More_Info/PELTOLP213....gJlL_D_BwE
$11.75
RWK
RWK is offline
PostPosted: Wed Jul 09, 2025 10:36 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
What I have, made by Precision Brand also. Use them in my real job to.
https://www.mcmaster.com/2058A11/
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
daveblank
PostPosted: Wed Jul 09, 2025 10:43 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
I use my tools for a living. Buy once, cry once! These make running the valves on diesels a breeze. If i want a single instead of mucking with the whole set they come off the ring quick & easy.
Schepp
Schepp is offline
PostPosted: Wed Jul 09, 2025 11:44 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
I've got a nice Starrett set but it hardy gets used. The long singles get used the most. Its always the same job over and over. For machine work I use a .02" to touch off tools, for the vw its a .006"
Unless you're doing a variety of work no need to buy a full set.
Cusser
Cusser is offline
PostPosted: Wed Jul 09, 2025 12:01 pm    Post subject: Re: lets see your favorite feeler gauge Reply with quote
My feeler gauge is like 50 years old, and the "0.006 inches" is practically all worn off.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Wed Jul 09, 2025 1:33 pm    Post subject: Re: lets see your favorite feeler gauge Reply with quote
I use a single blade from a 12” long set. My Snap On dealer was cool enough to order me 4 of them. I still am working on the first one 30 years later! This was actually straight when purchased!
Better than using those tiny blades. Makes it way easier!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
raygreenwood
raygreenwood is offline
PostPosted: Thu Jul 10, 2025 8:43 am    Post subject: Re: lets see your favorite feeler gauge Reply with quote
If one is willing to pay $120 for a set of feeler gauges....I would not spend it on Snap-On. Just spend it on a set of Starrett tapered blades.
Depending on how accurate you want your feeler gauges to be Laughing ....when measured with a good 0.0001" micrometer, the Starrett gauges are more accurate than the Snap on (though the Snap on's are no slouch).
But, the best bang for the buck...nearly equal to Starrett are the Mitutoyo sets. Ray
daveblank
PostPosted: Thu Jul 10, 2025 1:58 pm    Post subject: Re: lets see your favorite feeler gauge Reply with quote
Show me the equivalent Starrett set. They must include the handles! I won't do another 60 Series Detroit rockers without the handle.
earthquake
earthquake is offline
PostPosted: Wed Jul 16, 2025 4:21 pm    Post subject: Re: lets see your favorite feeler gauge Reply with quote
I you have a good Hardware store near buy [Not Lowes or HD] you buy single 12" feeler gauge blades pretty cheap, I pick up a .002 blade awhile back from McFadden-Dales for a project and I seam to recall it was only 3.00$ but it was a few years ago.
OK, I just called McFadden- dales and a .006" single 12" blade is $6.10
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
