Rekeying a lock - Tutorial FAQ
chrisgooner
chrisgooner is offline
PostPosted: Tue Aug 28, 2012 2:31 am    Post subject: Reply with quote
Hi guys I'm trying to re-key my tailgate lock on my 79 bay. I've unscrewed the latch at the back of the lock and taken it off, there doesn't appear to be a retaining clip, should there be one? the barrel is in tight and won't come out.
Wasted youth
Wasted youth is offline
PostPosted: Tue Apr 02, 2013 10:27 pm    Post subject: Reply with quote
I have removed the lock and cannot get any of the wafers to come out of the barrel. I have thoroughly cleaned it with solvent. All the wafers are nicely sprung, and have uniform movement, except for the one offender which sits high with the key in.
Removing the key and trying to get the wafers out proves fruitless. There must be a way, but I am stumped. I read all six pages of the thread, but didn't see anywhere on how to get the wafers out, just cautions against them from flying out when the key is removed. (I should be so lucky!)
What did I overlook Question
1977 bus, rear hatch lock.
It's kickin my ass! Embarassed
suffecool2
suffecool2 is offline
PostPosted: Mon Apr 08, 2013 5:12 pm    Post subject: Reply with quote
Just redid my engine hatch lock on my '71, thx to the O.P.
Saved me some bread Very Happy
'71 Hightop - rolling resto/customization in process
'87 Golf - tranny's toast, but still runs
'70 bone stock Westy - gone Sad
obnoxiousblue
obnoxiousblue is offline
PostPosted: Mon Apr 08, 2013 5:47 pm    Post subject: Reply with quote
With the key in the cylinder, and the wafers sticking out... Would it be ok to run them against a grinder to shave down the protrusions?
Or is that a no no?
Mike
1964 Beetle
2001 Eurovan Camper
suffecool2
PostPosted: Mon Apr 08, 2013 6:07 pm    Post subject: Reply with quote
Or is that a no no?
I was going to dremel the offending wafers, but chickened out & just removed them.
busdaddy
busdaddy is offline
PostPosted: Mon Apr 08, 2013 6:14 pm    Post subject: Reply with quote
Or is that a no no?
That would be the hillbilly way to do it, not pretty and sometimes a big fail but better than removing them all. Why not just let the moths out of the wallet and have Steelersbus or Gabe rework it so it'll be 100% good for the next 40ish years?, it really doesn't cost that much and it won't give you trouble in your lifetime, can you say that about the grinding?
You may also want to ask your local oldschool locksmith about it, some are still capable of reworking them properly, be sure to confirm how they plan to fix it before leaving it with them though.
Слава Україні!
suffecool2
PostPosted: Mon Apr 08, 2013 6:25 pm    Post subject: Reply with quote
Embarassed I only had to remove 3, was still 3 or 4 left, felt that it was a better option than the dremel, this way I can still get it done by Steelersbus later. I still have the wafers to put back in.
obnoxiousblue
PostPosted: Mon Apr 08, 2013 6:36 pm    Post subject: Reply with quote
BusDaddy, I already did actually. Gabe did mine a few years ago, and my key works all the doors, trunk and ignition.
I was foolish, in that my handles have some pitting. I'd like to get new handles, and figured it'd be worth experimenting with.
Though, I think ican just put my cylinders in whatever new handes I buy.
Right?
Mike
1964 Beetle
2001 Eurovan Camper
busdaddy
busdaddy is offline
PostPosted: Mon Apr 08, 2013 7:30 pm    Post subject: Reply with quote
Right?
Right, as long as they are from a similar year or code prefix group.
Слава Україні!
Wasted youth
PostPosted: Tue Apr 09, 2013 11:01 am    Post subject: Reply with quote
Funny. I have my cylinder and lock all dissasembled, and although all the wafers slide nice and are spring loaded, I CANNOT get any of them to come out. Yes, the key has been removed. They all have the same feel of being locked in or at a limit stop or similar.
All the warnings of not letting them fly out don't seem to apply to mine Confused
(1977 bus trunk/rear hatch lock)
suffecool2
PostPosted: Tue Apr 09, 2013 11:38 am    Post subject: Reply with quote
I had to GENTLY squeeze a couple of mine to remove them, up as close as you can to the cylinder.
busdaddy
busdaddy is offline
PostPosted: Tue Apr 09, 2013 11:50 am    Post subject: Reply with quote
Feel fortunate your lock isn't worn too badly Smile
Слава Україні!
suffecool2
PostPosted: Tue Apr 09, 2013 11:58 am    Post subject: Reply with quote
I was sweating bullets the whole time I was messing with it, don't like messing w/small delicate stuff like that Pray
Bigger parts where if ya slip a little & it don't matter are more my style Twisted Evil
I could take my key all the way out & all the wafers would stay put Shocked thats when i got nervous trying to figure out what to do, cause everyone was saying to be careful that they go flying, when all of mine were stuck!
Wasted youth
PostPosted: Tue Apr 09, 2013 9:04 pm    Post subject: Reply with quote
I found out after I finally got one of them out today that mine have a second shoulder, a little lower down. It seems to be designed to retain the wafer so it doesn't come flying out when beginning to disassemble. It also seems as though when wafers are installed, a slight peening action on the barrell body is made to trap that lower shoulder.
Dipsy
Dipsy is offline
PostPosted: Thu Apr 11, 2013 5:45 pm    Post subject: Reply with quote
I've just been rekeying my tailgate lock on my split tonight (to match my cab doors). I dug out all my old handles and stripped them down for parts, and the tailgate had that exact same 'peening' over. It made them a little more troublesome to get in and out, but it did at least stop everything flying off everywhere Smile
Cheers,
Nige.
odamark
odamark is offline
PostPosted: Mon May 27, 2013 4:22 pm    Post subject: Rekeyed and good to go! Reply with quote
Had a key stolen, so I replaced the ignition switch and then rekeyed all of the doors, courtesy of this post! Much appreciated!
Rippers
Rippers is offline
PostPosted: Wed May 21, 2014 3:10 pm    Post subject: Reply with quote
I bought another bus on the weekend and the sliding door handle lock won't turn with any of the supplied keys, given it a soak with penetrating oil and nothing. Decided to take the lock tumbler out and key it to either the ignition or passenger door keys. Got the little grub screw out easily but the tumbler is stuck fast.
What I would like confirmed and like to know is
1. does the deadlock not come out unless the tumbler is out?
2. with the grub screw removed will the tumbler rotate inside the handle.. i.e. could i put a flathead screw driver and turn it free to remove
3. any tips on getting the tumbler out? I don't have the key for it so was just using another spare to try and grip inside to pull it out.. no luck. Also tried heat on it with no luck.
Thanks Paul
busdaddy
busdaddy is offline
PostPosted: Wed May 21, 2014 4:03 pm    Post subject: Reply with quote
Read page 2 again, the cylinder should come out locked or not once the grub screw is out unless it's corroded in so bad it won't even wiggle a tiny bit, you'll likely have to lift the wafers down in the keyslot with a tiny screwdriver or wire a little as you pull on it to get them over the outer edge.
Слава Україні!
Rippers
Rippers is offline
PostPosted: Wed May 21, 2014 4:26 pm    Post subject: Reply with quote
It doesn't move in any direction sadly. I have read page two over a few times can you confirm points 1 & 2 thou please
Also can you elaborate a little on 'lift the wafers down in the keyslot with a tiny screwdriver or wire a little as you pull on it to get them over the outer edge'
busdaddy
busdaddy is offline
PostPosted: Wed May 21, 2014 5:27 pm    Post subject: Reply with quote
No the deadbolt won't come out until the cylinder is out at least 1/4"
Removing the screw does nothing to unlock the cylinder, the screw keeps it from coming out of the handle.
When you put the properly coded key into the cylinder it retracts all the wafers so the cylinder is smooth on the outside and can turn freely, with no key they are all sticking out both sides and engaging slots in the handle so the cylinder won't turn. To remove the cylinder with no key remove the set screw and bend a piece of wire so you can hook it into the key hole and pull the cylinder away from the handle (out), then while pulling on that reach in there with a tiny screw driver and simulate a key pushing up and down on the spring loaded wafers so they are lifted/pushed out of the slot in the handle and can clear the non slot area surrounding the end of the cylinder on the outside of the handle. It takes some fiddling and experimenting to find the right spot where each one clears but if you keep pulling while you play and don't let the cylinder go back in you'll get it out one little notch at a time, don't pull so hard you restrict the movement of the wafers, just a gentle steady pull is usually enough.
Слава Україні!
Page 6 of 8
