What about an emphasis on the 1200cc/40 hp motor.
WesleyGarrard
WesleyGarrard is offline
PostPosted: Sat Nov 29, 2008 8:04 pm    Post subject: Reply with quote
what would it take to run straight cut cam gears in my 40 hp, is it a simple bolt on procedure or would there have to be alot of modification
Matthew
Matthew is offline
PostPosted: Mon Dec 01, 2008 7:39 pm    Post subject: Reply with quote
It would be the same parts and procedure as installing them in a 1600 based engine.
1965 Beetle sedan
Click to view image
WesleyGarrard
PostPosted: Mon Dec 01, 2008 8:38 pm    Post subject: Reply with quote
that is exactly what i thought i just wanted to be sure
stede
Location: Buckeye,AZ by way of El Sereno Rifa, Sur Califas 13
stede is offline
PostPosted: Tue Dec 09, 2008 1:28 pm    Post subject: Re: My slightly modified 40hp Reply with quote
[/quote]
This baby looks mean ! Try to get some video of smokin the tires ?
[email protected]
oldspeed@flash.net is offline
PostPosted: Wed Dec 10, 2008 12:07 am    Post subject: blow through turbo stock carburetor Reply with quote
blow through turbo on a 1493. was a 1200, added 83 big bore, added 69 crank, narrowed 40hp rods, straight cuts, new generation vw turbo, HKS pop off valve, modified stock carburetor
Old Speed
Russell Ludwig
stede
stede is offline
PostPosted: Thu Dec 11, 2008 8:36 am    Post subject: Reply with quote
that shit is insane ^^^^^^^^. What type of HP do you get outta that ?^
stede
stede is offline
PostPosted: Mon Dec 15, 2008 7:34 am    Post subject: Reply with quote
where can I find a hi performance muffler for my 40Horse ?
[email protected]
PostPosted: Mon Dec 15, 2008 3:42 pm    Post subject: exhaust Reply with quote
an inexpensive EMPI 3300 will fit. it retails for about $65. you can view it at www.empius.com
we have it in stock
bugpack still makes a header and it is $67 for the header only. it is the typical 4 into one header. we don't have it in stock but we can get it
old speed
7311-a madison st.
paramount ca
90723
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Mon Dec 15, 2008 8:55 pm    Post subject: Reply with quote
I bought the Bugpack header a few months back for my 40 horse, the flange is the same position as a 1600 header so it bolts right up to my hideaway muffler. Should be nice and quiet after I get it flanged and coated.
Looking for aluminum single port Kadron manifolds.
stede
stede is offline
PostPosted: Tue Dec 16, 2008 6:39 am    Post subject: Re: exhaust Reply with quote
we have it in stock
old speed
7311-a madison st.
paramount ca
90723
Thanks. I have my pops cruise by and put a order in for me.He works down the street from your shop.
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sun Sep 06, 2009 9:58 pm    Post subject: Reply with quote
Old thread, thought it would be the best to post in as a search pulled no results.
Rebuilding a factory rebuilt case with late 373 square boss heads and NOS Cima 77mm replacement P&Cs.
My question is...
Do I use the 40hp pushrod tubes or can I run regular 1600 tubes?
If I need the 40hp tubes what is the best source??
WesleyGarrard
PostPosted: Mon Sep 07, 2009 6:28 am    Post subject: Reply with quote
cannot use 1600 tubes they are longer than the 40hp tubes. wolfsburg west has them. maybe cip 1. but not alot of places carry them
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon Sep 07, 2009 7:06 am    Post subject: Reply with quote
I've used German and Mexican made 1200 tubes, both seemed about the same in quality. I'm not sure what country the ones you can buy currently are from though. Some links
http://www.busdepot.com/details.jsp?partnumber=113109335
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113109335
http://www.cbperformance.com/catalog.asp?ProductID=119
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D109%2D335
shano63 Premium Member
shano63 is offline
PostPosted: Mon Sep 07, 2009 9:23 am    Post subject: Reply with quote
I just bought some at http://www.wolfgangint.com/Parts/Push+Rod+Tubes/Type+1/ Still waiting on them...
63 T1 Ragtop Gulf Blue
20 Toyota Corolla 6spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
CLASSIC CAR GUY
Transport and Title Guru
Location: Phoenix AZ, but originally from Long Island NY
CLASSIC CAR GUY is offline
PostPosted: Thu Oct 14, 2010 11:34 pm    Post subject: Reply with quote
good thread looks like 40hp hot rods are alive and kickin' im doing one right now as well,,,
(0\!/0)
58' Rag'
60' Type 1
61' Type 1
62' Type 1
64' Type 1
66' Type 1
66' Vert'
67' Type 1
"every one wants to reinvent the wheel, but nobody knows how to make it round"
Vintage Volkswagen Sales and Service as well as Classics and Muslcecars all located here in Phoenix Arizona at www.rpmotorcars.com
View user's profile Send private message Visit poster's website Facebook Twitter Gallery Classifieds Feedback
[email protected]
PostPosted: Thu Feb 03, 2011 10:32 pm    Post subject: Reply with quote
i just posted a set of 92mm big bore 40 hp pistons and cylinders under performance engine parts if anyone is interested.
I have saved them for years intending to use them but you know
[email protected]
PostPosted: Sat Feb 05, 2011 9:55 am    Post subject: Reply with quote
something else interesting about these pistons and cylinders is that cast into them inside is NPR-DEANO.
I heard that Dean Lowry was responsible for getting NPR into making VW piston and cylinder sets and distributing them in the U.S. but then they screwed him over and sold direct to warehouses. Anyone know what happened for sure?
The Android
PostPosted: Sat Feb 05, 2011 11:18 am    Post subject: Reply with quote
92mm? Never heard of that one before! I've heard of 82mm for the 1200, but not 92. Cool.
[email protected]
PostPosted: Sat Feb 05, 2011 12:46 pm    Post subject: Reply with quote
actually it's 83 that you have heard of to build the popular 1385 of the mid eighties.
now AA is making them so they are pretty cheap
touchdowntodd
touchdowntodd is offline
PostPosted: Thu May 12, 2011 5:58 pm    Post subject: Reply with quote
bump to the top since i still dream of dual carbs or a reasonable carb upgrade for my 40hp ... and i still am thinkin about which exhaust to get..
thinkin merged with a quiet pack .. thoughts?
its a 40hp from '65 rebuilt and seems very strong.. how can i tell if it has 83 cylinders?
mine - '73 Thing .. brms/drop coming
LOOKING for a pre 67 bug
Page 8 of 10
