heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7557 Location: Houston, Texas
Posted: Thu Oct 24, 2024 8:43 am Post subject: Re: Engine issue has me stumped |
| Heiferman wrote: |
| Glad you got it going. It can be a confusing battle at times. I am in the middle of advance v rich v retard v advance right now on a big engine I know nothing about.. congrats |
Sometimes it's easier to just use the advance side of the distributor instead of both the advance and retard. Plugs the retard side and try to use just the advance. See if that works for you. You will need to time the engine differently when using advance or advance with retard. _________________ www.vwnos.com [email protected]
Heiferman Samba Member
Joined: February 28, 2024 Posts: 401 Location: Georgia, USA
Posted: Sun Oct 27, 2024 5:42 pm Post subject: Re: Engine issue has me stumped |
| heimlich wrote: |
| Heiferman wrote: |
Sometimes it's easier to just use the advance side of the distributor instead of both the advance and retard. Plugs the retard side and try to use just the advance. See if that works for you. You will need to time the engine differently when using advance or advance with retard. |
Sorry, my post was cryptic. It's a 009. But it will not start at 7.5 BTDC and wants far more advance to start or begin to run smoothly (like 10-12 and like 40 at 3000rpm) so it has been frustrating me. _________________ - 1973 Thing, 1970 Ghia, some LandCruisers and an old Ambulance |
heimlich  VWNOS.com
Posted: Sun Oct 27, 2024 5:49 pm Post subject: Re: Engine issue has me stumped |
| Heiferman wrote: |
| heimlich wrote: |
| Heiferman wrote: |
Sorry, my post was cryptic. It's a 009. But it will not start at 7.5 BTDC and wants far more advance to start or begin to run smoothly (like 10-12 and like 40 at 3000rpm) so it has been frustrating me. |
40 is too much. Sounds like it is advancing too much. A 009 usually advances 22 degrees. You are saying there is 28 or 30 degrees. Do you have a Bosch 009? I can tell you how to limit the advance but there might be something else wrong with your distributor. You should open it up and check it out. _________________ www.vwnos.com [email protected]
