68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Mon Feb 04, 2013 7:01 pm Post subject: |
| Got a question , how much are they supposeto flex when turning steering wheel ? |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13620 Location: West Coast, USA
Posted: Mon Feb 04, 2013 7:08 pm Post subject: |
| 68IHscout wrote: |
Probably exactly zero degrees. They are intended to take small vibrations form the road and engine out of the steering wheel, not flex…… _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
Posted: Mon Feb 04, 2013 7:16 pm Post subject: |
| asiab3 wrote: |
| 68IHscout wrote: |
Probably exactly zero degrees. They are intended to take small vibrations form the road and engine out of the steering wheel, not flex…… |
There are occasions where misalignment actually makes them flex, but their real job is to break/bend away in an accident, so the whole column, collapsible bracket, and steering wheel shaft can splat wherever your body rams them. Early solid steering shafts (splitties) could rupture your internal organs with a unyielding steering wheel rim.
Colin _________________ www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/ |
Posted: Mon Feb 04, 2013 7:18 pm Post subject: |
Ah- I thought that was the web-like internal section on the shaft that did that. _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4143 Location: Los Gatos,Ca.
Posted: Mon Feb 04, 2013 7:18 pm Post subject: Steering coupler |
They really won't deflect much when new providing your front end is in
good condition all the way from proper tire pressure to steering box and
all in between
Ball joints
center pin
Etc..
if in doubt and you have looked at the previous posts in this thread
buy a new GERMAN one from www.wolfsburgwest.com.
don't buy a cheap euromax or others that claim to be good. _________________ V.W.owner since 1967 |
Posted: Mon Feb 04, 2013 7:20 pm Post subject: |
| asiab3 wrote: |
| Ah- I thought that was the web-like internal section on the shaft that did that. |
That is only on Beetles and Type 3s where they also have to *collapse the shaft* as the steering box and front suspension jump at your feet in the crash.
ColinDeathOfTheParty _________________ www.itinerant-air-cooled.com
Posted: Mon Feb 04, 2013 7:21 pm Post subject: |
| asiab3 wrote: |
| 68IHscout wrote: |
we install one on a 74 and tbe darn thing flexes like about half maybe more inch before the wheel starts turning , brngs the steering wheel up too and now the horn honks when turning , I wonder if the disk flexing that much will cause it to honk? |
curtis4085 Samba Member
Posted: Mon Feb 04, 2013 7:25 pm Post subject: Re: Steering coupler |
| old DKP driver wrote: |
all in between
Ball joints
center pin
Etc..
don't buy a cheap euromax or others that claim to be good. |
WW all out of the German VW... i bought off there site two weeks ago and was sent generic. I ended up buy 3 from Cip1.com ..
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D211%2D415%2D417%2DGR _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53171 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Feb 04, 2013 7:45 pm Post subject: |
| 68IHscout wrote: |
| asiab3 wrote: |
| 68IHscout wrote: |
Sounds like you got a bad coupling, where did you buy it? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Feb 04, 2013 8:04 pm Post subject: |
| If you don't have something that will flex in the steering shaft there is a real chance of the shaft fatiguing and breaking with time. I have known this to happen on several older vehicles. I have never heard, but perhaps the flex couplings were mandated at some point to address the breakage problem. |
Posted: Mon Feb 04, 2013 8:23 pm Post subject: |
| Wildthings wrote: |
It was the Big Deal Safety Update of 1968. Check the advertising.
Posted: Mon Feb 04, 2013 9:56 pm Post subject: |
| @busdaddy.....dont know where it came from , it looks well made but then again it doesnt say vw on it. But definetly will take a look at suspension parts and preasure on tires ..thanks for replies... |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1603 Location: Indianapolis, IN
Posted: Wed Mar 20, 2013 3:03 pm Post subject: Re: Steering coupler |
| curtis4085 wrote: |
all in between
Ball joints
center pin
Etc..
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D211%2D415%2D417%2DGR |
I received and installed a German VW shift coupler from WW today. _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
larryducas Samba Member
Joined: October 25, 2011 Posts: 233 Location: Fallbrook, CA
Posted: Wed Mar 20, 2013 7:37 pm Post subject: |
| 68IHscout wrote: |
| asiab3 wrote: |
| 68IHscout wrote: |
The horn honks because the wire touches as the wheel turns. Make sure the lug is bolted on the bottom side of the rubber coupling thru the middle hole of the rubber
. The top side will make it honk. _________________ 71 deluxe, 1968 type 1 engine rebuilt, 009 distributor, pertronix module, Empi 38 EPC / DGES carb |
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 3036 Location: Commack, NY
Posted: Sun Apr 07, 2013 5:32 pm Post subject: |
Got my new coupler, it isn't marked at all... But doesn't look or have the shape of the Euromax ones.
Was told, it's German... But well, you know how that goes.
Worth installing? It seems to have a layer sandwiched in it, not sure if it's the mesh described herein but I'll defer to the general opinion...
_________________ Mike
1964 Beetle
2001 Eurovan Camper |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42917 Location: at the beach in Northern Wokistan
Posted: Sun Apr 07, 2013 7:11 pm Post subject: |
| obnoxiousblue wrote: |
Richard at OE Vee Dub before he sold out shipped me a genuine VW one. Only it didn't say VW so he sent me another that did. When I compared them I found that the only difference was that the VW was ground off the first one. All other marks and casting flaws were the same identical. Whomever VW contracted out to also sold them on the market but had to grind off the VW Audi logo. If you have one made in the EU or Germany that has a grind mark on it, it still may be an original VW one. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
fusername Samba Member
Joined: March 15, 2006 Posts: 2899 Location: Boston MA
Posted: Sun Apr 07, 2013 8:26 pm Post subject: |
good to know. I parted out my bus and found that the ~4 year old coupler had already started degrading noticably. will check the new one on the new bus. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
| Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Posted: Sun Apr 07, 2013 8:33 pm Post subject: |
Wow, that fast?
The one on my bus is badly cracked, it has a chunk missing too.
So I'm inclined to say anything is better than the ticking time bomb I have.
This one has no VW marks on it however it does have the letters LEGAR on it. It feels very firm, resists my attempts to flex it, and seems to have a middle layer in it, I don't know if its a mesh or just a higher density rubber.
Going to try to get it in tomorrow. I really want to avoid pulling the column apart again. _________________ Mike
1964 Beetle
Posted: Sun Apr 07, 2013 9:20 pm Post subject: |
what I did and got away with, is crawl underneath and remove the 1 pinch bolt that holds the lower flange to the steering box, then you can pull the whole thing up w/ the column and everything. then you don't need two people or 5 foot long arms to hold a wrench above and below the floor! _________________ [email protected]
Posted: Mon Apr 08, 2013 4:07 pm Post subject: |
Done
1964 Beetle
