Loren  Samba Member
Posted: Fri Dec 22, 2023 2:38 pm Post subject: Re: What's this Ghia part and Where does it go? |
Here is one of the plates installed on my 59 Ghia
obus  Samba Member
Joined: March 08, 2001 Posts: 11776 Location: just off Garden State Parkway Exit 81
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4147 Location: In Molinya Orbit
stcj Samba Member
Joined: October 15, 2008 Posts: 90 Location: Melbourne, Australia
Posted: Mon May 06, 2024 6:01 pm Post subject: Re: What's this Ghia part and Where does it go? |
Part came with doghouse tinware set, doesn't look like hoover bit:
EverettB  Administrator
Joined: April 11, 2000 Posts: 71871 Location: Phoenix 602
craigolio1 Samba Member
Posted: Sun Aug 25, 2024 3:00 pm Post subject: Re: What's this Ghia part and Where does it go? |
Hey all.
What’s this hose for? I’m looking at a car which has a port for it on the engine but the hose is not there.
Thanks!
_________________ Located in the Toronto area.
1971 Ghia Convertible
Join me on my Karmann Ghia journey.
https://www.thesamba.com/vw/forum/viewtopic.php?p=10441921#10441921 |
NoDents Samba Member
Posted: Sun Aug 25, 2024 3:18 pm Post subject: Re: What's this Ghia part and Where does it go? |
Should have a tube underneath that will suck warm air from under the 1-2 cylinders.
Part number 113-129-511. D or E _________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
Posted: Sun Aug 25, 2024 3:37 pm Post subject: Re: What's this Ghia part and Where does it go? |
| NoDents wrote: |
Part number 113-129-511. D or E |
Thanks so much for the reply.
Where does it send the warm air, and what doesn’t work if it’s missing?
Edit: looks like it’s a pre-heating tube. Sends warm air to the air cleaner to preheat the air being drawn in. Does that sound right?
Edit: and then i found this!!!
https://www.thesamba.com/vw/forum/viewtopic.php?p=10112848&sid=e3f62337669b497851e2300df5fa3daf
Thanks for giving me a direction to go.
Thanks!
Craig _________________ Located in the Toronto area.
Posted: Sun Aug 25, 2024 5:51 pm Post subject: Re: What's this Ghia part and Where does it go? |
OK, you found it. However yours would use a bigger tube than the one in the 66 thread. _________________ No Dents
Posted: Sun Aug 25, 2024 6:17 pm Post subject: Re: What's this Ghia part and Where does it go? |
| NoDents wrote: |
| OK, you found it. However yours would use a bigger tube than the one in the 66 thread. |
Noted. Thank’s again.
Craig. _________________ Located in the Toronto area.
mike yapps Samba Member
Posted: Sat Jun 21, 2025 6:42 am Post subject: Re: What's this Ghia part and Where does it go? |
I need help identifying these parts. Looks like the glovebox lid is ghia, but not sure what years. The housing looks to be the same color as the lid so I’m assuming it’s also ghia? But not sure what it is since I’m not too knowledgeable with ghias. Please help me out. I’m also looking to sell these so that’s why I am asking. |
Vintrick  Samba Member
Posted: Sat Sep 06, 2025 4:42 am Post subject: Re: What's this Ghia part and Where does it go? |
I have been searching far and wide to find a special seal...
My KG is a1968 Coupe but I know it's on most other years as well.
The seals go on each side of the engine bay floor against the body and are about 4 inches long. There's about a 1/4 inch gap between the engine bay floor and the body and these seals go in the gap.. I am including some photos for reference.. The first two photos are a side shot that shows the shape better.
Hopefully someone can identify it and let me know where I can obtain it from....
Thank you!
Posted: Sat Sep 06, 2025 10:13 pm Post subject: Re: What's this Ghia part and Where does it go? |
| Vintrick wrote: |
Thank you! |
This seal has the same profile as the inner guard to nose as well as the mud splash panel in the back of the front guard.
https://airheadparts.com/vw-part/door-hinge-pillar-cover-plate-seal-141-805-381/
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Posted: Sun Sep 07, 2025 5:14 am Post subject: Re: What's this Ghia part and Where does it go? |
sputnick60, Thank you!! That is the one!!  |
SYS64738 Samba Member
Joined: October 13, 2022 Posts: 36 Location: BC, Canada
Posted: Thu Sep 18, 2025 10:31 pm Post subject: Re: What's this Ghia part and Where does it go? |
Hi folks, any ideas what these two parts are?
The black plastic box looks like a cover box for something. It's got a couple little metal tabs on the sides that look like they'd hook into some slots somewhere.
And the little canister thing with the wingnut on it is connected to a hose that is open on one end and on the other end caped off with that eyelet fastener.
Grateful for any ideas! Thanks!
Edit: I'm pretty sure the hose with the canister and the eyelet ring was part of an old Eberspächer gas heater that was once installed in this ghia. |
Posted: Sat Nov 01, 2025 4:10 pm Post subject: Re: What's this Ghia part and Where does it go? |
Hey everyone.
What is this?
It’s in a 1971 Ghia. I have a 1970 parts car and it does not have one…. Doesn’t mean it didn’t at one time. Part of a vapour recovery system? Emissions?
Ultimately I’d like to remove it. My trunk smells like gas and I’m trying to figure out what to fix. I’ll start with couplings and seals and such but I’m curious if I need this?
Thanks.
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4213 Location: Georgia
Posted: Sun Nov 02, 2025 1:16 pm Post subject: Re: What's this Ghia part and Where does it go? |
It’s the evaporation canister. Part of the early emission control system. There should be a charcoal canister in the engine compartment.
You can remove them if you wish. They’ll have no effect on your fuel smell. Usually, the smell comes the filler tube and old cracked breather lines and fuel lines.
If you do decide to remove it, do so carefully and sell it or give it away in the classifieds here. There are people looking for them for restoration purposes. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Sun Nov 02, 2025 2:49 pm Post subject: Re: What's this Ghia part and Where does it go? |
| jeffrey8164 wrote: |
If you do decide to remove it, do so carefully and sell it or give it away in the classifieds here. There are people looking for them for restoration purposes. |
Thank you.
I’ll make sure it finds a good home.
54rag Samba Member
Posted: Fri Nov 14, 2025 4:06 pm Post subject: Re: What's this Ghia part and Where does it go? |
Ghia part?
_________________ Il est grand le mystère de la DR |
MTT3107 Samba Member
Posted: Wed Nov 26, 2025 11:09 am Post subject: Re: What's this Ghia part and Where does it go? |
Found this among other parts which came with my Ghia..
No idea what it is
