'73 Super HL Switch ON, No RTurn Signal or Flashers - FIXED???
Page: Previous  1, 2, 3, 4, 5
vamram Premium Member
vamram is offline
PostPosted: Wed Jul 02, 2025 6:48 pm    Post subject: Re: '73 Super HL Switch ON, No RTurn Signal or Flashers Reply with quote
Holy guacamole, Batman! Er, Ashman! You may have hit on something! I removed the plug over 5 years ago when I was finishing the build, but I left the harness wires wrapped behind the fan shroud, thinking someday I may have a use for them. At the time, I wrapped each end w/electrical tape, but w/the years and miles, it looks like some of the ends are now exposed - including at least the matching black/green stripe wire!!!
Tomorrow I'll clip the connectors from each wire and dip the ends in liquid electrical tape, reassemble my dash and poke the bear again.
Click to view image
Save the Supers!!
ashman40
ashman40 is offline
PostPosted: Thu Jul 03, 2025 4:16 am    Post subject: Re: '73 Super HL Switch ON, No RTurn Signal or Flashers Reply with quote
Good luck! Pray
AshMan40
vamram is offline
PostPosted: Thu Jul 03, 2025 3:59 pm    Post subject: Re: '73 Super HL Switch ON, No RTurn Signal or Flashers Reply with quote
Ashman, you have a great eye!!! IT *MIGHT* BE FIXED!
Lest I forget, I took a picture of the bloody mess I had w/the dashboard tracing wires and grounds. I reassembled everything after this picture.
Then I went around back, cut the ends of of the diagnostic block wires, dipped them in liquid electrical tape, let them dry then zip-tied them the f*#k outta the way.
Then I went on a 20-mile city-highway cruise, over hills, speed bumps, many right turns and lane changes, w/the parking and HLs on the whole time....
NOT A SINGLE FAILURE OF THE TURN SIGNALS!!
Thank the samba gods! IF THIS HOLDS (you'll forgive my unchecked pessimism), I can move on to finishing the re-rebuild of my '74's motor and replacing its gas tank.
I know turn signals and parking circuit, and testing light and e-switches better than I ever wanted to. I probably have the cleanest rear and front light assemblies of any car on the samba (well, of any daily driver perhaps). In the process I managed to break and fix my factory wiper switch, fixed the radio's ground, replaced suspect parking bulbs...cursed a ton. Wow, man am I having a beer or two tonight. Or maybe Rum 'n' Cokes, yeah...!
Click to view image
Save the Supers!!
Page 5 of 5
