Thing seatbelt bolt size..?
VTAthing
VTAthing is offline
PostPosted: Sun Jan 30, 2005 10:03 am    Post subject: Thing seatbelt bolt size..? Reply with quote
Hello, I was wondering if anyone would know the size (im guessing in MM?) of the bolt that goes into the seat belt holes on my thing as well as the length ? Im putting in new seat belts and need to but the correct bolt size.....Thanks for your time Dave
germansupplyscott
germansupplyscott is offline
PostPosted: Sun Jan 30, 2005 11:28 am    Post subject: Reply with quote
m10 x 1.0, it is fine thread. seatbelt fasteners are also very hard, usually grade 10.9 or better. i think it is about 26mm long.
SL
Vw4x4
Vw4x4 is offline
PostPosted: Sun Jan 30, 2005 12:04 pm    Post subject: Reply with quote
Dave,
Usually when you buy new seat belts, they come with their own hardware, bolts, washers,etc. The info that Scott is pretty acurated.
kubelmann
kubelmann is offline
PostPosted: Sun Jan 30, 2005 4:07 pm    Post subject: Reply with quote
The original Seat belt bolts have the thread as Scott said but they also have a larger smooth shaft that allows the seat belt to rotate. They are a very hrad bolt ( grade 10+) that will be nearly impossible to replace other than the original part. I would contact Mike Basso at Things Unlimited as he will sell you the correct parts for a fair price. If he is unable to help you I have some spare seat belt bolts that will solve your problem. I highly reccomend you use only the actual part. K-mann
VTAthing
VTAthing is offline
PostPosted: Tue Feb 01, 2005 6:45 pm    Post subject: Reply with quote
Thanks everyone for the info On the parts....
