hlwimmer Samba Member
Joined: May 29, 2002 Posts: 533 Location: concord, calif.
Posted: Wed Feb 02, 2005 8:45 pm Post subject: cigarette lighter in place of ignition switch? |
anyone done it? i just picked up a wired steering lock that would make it possible. would be nice to have both a locking steering column, a lighter and no additional holes in the dash... pictures (inside + out)? |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Wed Feb 02, 2005 8:55 pm Post subject: |
The lighter requires quite a bit bigger hole which negates ever putting an ignition switch back in there if the Euro switch ever craps out. Lighters were usually on the right of the ashtray on 67 down cars. Sure it is possible to do though. I simply installed a 6v wiper switch w/a headlight knob and used it to power up a vintage rear fog light & left the hole the stock small size _________________ Midwest Autosavers, Inc. Woodstock, IL |
Posted: Wed Feb 02, 2005 8:59 pm Post subject: |
thanks... was thinking about the light switch, too (but i dont have fog lights yet). figured the hole would need to be bigger, as you mentioned, but goo dpoint about the euro switch crapping out...
we lighters stock for 64down? or an owner installed aftermarket accessory? |
Posted: Thu Feb 03, 2005 6:40 am Post subject: |
Lighters for all beetles until about the 78 converts were a dealer installed accessory. They are available with stock knobb & etc. I have seen them installed between the headlight & wiper switch but most were to the right of the ashtray. If you dont have a need for an accessory switch and just want to fill the hole, go to hardware store and get a small chrome washer used for trim screws and a washer for the back side along with a small screw to fit a headlight knob and just screw a knob over the hole.
I can supply you with an awesome old accessory rear fog or reverse light that fits under your license plate light if you want to have something to run a switch to !
Darby at [email protected] _________________ Midwest Autosavers, Inc. Woodstock, IL |
