Ball joint ??'s
oldbugs
oldbugs is offline
PostPosted: Fri Feb 04, 2005 6:31 pm    Post subject: Ball joint ??'s Reply with quote
I've never worked on a super before and my friend needs the ball joints replace on his '73? super vert. Is this something a do it yourselfer can do? thanks Kelly
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Fri Feb 04, 2005 8:27 pm    Post subject: Reply with quote
Yes our lucky the 71 -73 super is one of the only VW you can "bolt on" the ball joints... they are a bolt on with 3 bolts on the bottom of the strut/to control arm. have the other front end parts checked to as supers often need "everything" at some point or your pissing in the wind... and count on an alignment too.
slammed73SB
slammed73SB is offline
PostPosted: Sat Feb 05, 2005 6:47 am    Post subject: Reply with quote
i replaced the whole front end of my super in 1 weekend, it is like driving a new car, the onlt expensive part was the sterring box, $250 but it was worth itthe front steering is so tight now
