ROGER LAWLESS Samba Member
Joined: December 18, 2004 Posts: 238 Location: SANTA CRUZ, CA
Posted: Sun Feb 13, 2005 8:41 pm Post subject: Steering Box |
OK here it goes...
I have three stering boxes and I want to know which one is which...
First box #311-415-131, aluminum cover with Oil filler. Rough, worn spot. came in a box of stuff.
Second box, 311-415-131B aluninum cover with NO Oil filler, and the Pitman arm has a stub sticking out of ot about 2.5 to 3". The box was filled with grease. Works very smoothly. Also came in a box of stuff.
Third box, says TRW on the side with no numbers on the aluminum cover plate. Still on 64 pan. Too dark to find any other #s.
I have a 1963 pan that I am placing a 57 rag onto. The pan is almost complete except fot the steering box and tie rods, 3" narrowed beam.
Which is the correct one? I don't care if it is an original 57 I just want it to work correctly.
Thanks,
Roger |
