fotoroadie Samba Member
Joined: May 07, 2013 Posts: 180 Location: Manitowoc, WI
Posted: Tue Jul 12, 2016 4:49 pm Post subject: Re: Bus roof racks |
cdennisg wrote: |
fotoroadie wrote: |
What color to paint VW roof rack ?
Silver or Gray ? What shade ? Shiny or dull ?
whadayathink? |
They look best in dull grey galvanized, just like original. |
Thanks, what about the brackets ? These look so original but brown in color. ?
Are they supposed to be used as is ?
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20277 Location: Sandpoint, ID
Posted: Tue Jul 12, 2016 10:00 pm Post subject: Re: Bus roof racks |
Never seen them painted brown. Should be galvanized just like the rack. The lower inch or so should have a grey plastic coating like you have. _________________ nothing |
Posted: Wed Jul 13, 2016 5:45 am Post subject: Re: Bus roof racks |
Here's a image from Samba gallery that suggests there are other brown versions. ?? Anybody else have an opinion before I paint these & possibly ruin their original-ness.
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Wed Jul 13, 2016 12:26 pm Post subject: Re: Bus roof racks |
Are posting in the correct forum? I don't see a rack on that Fat Chick. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Wed Jul 13, 2016 2:26 pm Post subject: Re: Bus roof racks |
I got all the parts to refurbish my HWE rack.
_________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
Posted: Wed Jul 13, 2016 6:49 pm Post subject: Re: Bus roof racks |
EverettB wrote: |
cru62 wrote: |
Are posting in the correct forum? I don't see a rack on that Fat Chick. |
I think he was trying to say they match the Brown of that Bay Window
As far as I know roof rack clamps were never brown or color-matched |
Same here, but if those racks were somehow made to match a Champange bus that would be pretty neat. Definitely need some proof on that theory, though. _________________ nothing |
Posted: Fri Jul 15, 2016 10:18 am Post subject: Re: Bus roof racks |
Here is how I am making the legs for my rack. I sleeved the new metric tubing to the old tubing on the rack. I will weld them together and I am thinking about brazing the rest together like original.
cru62 Samba Member
Posted: Fri Jul 15, 2016 10:29 am Post subject: Re: Bus roof racks |
Red Fau Veh wrote: |
…….. I am thinking about brazing the rest together like original…...
I remember the last time I suggested brazing a rack instead of welding. Geez, you woulda thought I was suggesting heresy. There is less heat stress to a brazed joint. And what there is is spread out on a larger area, unlike the HAZ on a welded joint which can cause a weak margin. Personally, the reason I like brazing is that you can control the flow of the material and there is WAAAAY less cleanup of the joint afterwards. I have brazed racks and ladders. I was never concerned about the racks. I had some about the ladders because I didn't want a rung to release under pressure while climbing on it. But, I never had a problem. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Posted: Sun Jul 17, 2016 9:14 pm Post subject: Re: Bus roof racks |
cru62 wrote: |
I remember the last time I suggested brazing a rack instead of welding. Geez, you woulda thought I was suggesting heresy. There is less heat stress to a brazed joint. And what there is is spread out on a larger area, unlike the HAZ on a welded joint which can cause a weak margin. Personally, the reason I like brazing is that you can control the flow of the material and there is WAAAAY less cleanup of the joint afterwards. I have brazed racks and ladders. I was never concerned about the racks. I had some about the ladders because I didn't want a rung to release under pressure while climbing on it. But, I never had a problem. |
I agree, brazing those joints would be fine. And they will look nice, too. _________________ nothing |
Posted: Mon Jul 18, 2016 12:22 am Post subject: Re: Bus roof racks |
I made the legs this weekend. I used a bigger hammer right after that first attempt at mashing the end of a leg. I made the middle legs after mounting the rack onto the roof because the middle was bent and sagging a little and needed to be adjusted to be level.
CHASINGJR Samba Member
Posted: Wed Jul 20, 2016 5:11 am Post subject: Re: Bus roof racks |
Update: Finished Rack
Posted: Sat Sep 03, 2016 10:43 pm Post subject: Re: Bus roof racks |
I got the rack done today. Well it needs paint blending and sanding and I want to do something with the repro clamps. What color or finish do the original clamps have? It looks great on the bus, I love it!
CamBiscuit Samba Member
Joined: February 27, 2012 Posts: 82 Location: Adelaide Australia
Posted: Sun Sep 04, 2016 4:43 am Post subject: Re: Bus roof racks |
I got Chad - Ezycamper to send me out a kit. I used two less crossbars but otherwise stock and assembly was pretty easy.
_________________ 1965 ratty single cab
Instagram @cambiscuit |
consvws Samba Member
Joined: April 07, 2009 Posts: 950 Location: Roseburg, OR
Posted: Mon Oct 17, 2016 2:06 pm Post subject: Re: Bus roof racks |
can anyone get me some measurements from a full length vwoa bus roofrack? Need to know just general length & width, and how high it sits off the roof so the original clamps will work right. Thanks in advance |
bryanvw61 Samba Member
Posted: Tue Mar 28, 2017 3:29 pm Post subject: Re: Bus roof rack |
Has anyone heard of an ORIS roof rack?? Would love to know what it fits before I disassemble the cross rails and and make it fit my bus.
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Mar 28, 2017 4:58 pm Post subject: Re: Bus roof racks |
The ORIS name pops up as an OEM supplier of M-B racks- so perhaps it has German roots? It sure looks the part. It certainly goes on a sedan or wagon body- with it's longitudinal arc. If I were dead set on putting it on a bus, I don't think I'd feel too guilty cutting those two center cross bars in the middle and inserting a rod and matched tubing to take up the space.
Nice rack! _________________
EverettB wrote: |
FU#5 |
