M_atthewanderson Samba Member
Joined: January 25, 2005 Posts: 288 Location: Seattle
Posted: Thu Feb 17, 2005 12:04 am Post subject: 1980 vanagon fuel injection? problems listen to my story |
I have a 1980 VW Vanagon 2.0 fuel injected.
I was driving some long Seattle to Shelton Washington and just as I was taking the exit to Shelton my Vanagon just died on me. I had power but found the problem was now fuel pump. After some testing I found it was the relay and replaced it new. $100.00 at bow wow auto parts here in Seattle. Then it wouldn’t idle and the air flow meter was clinking and clanking so I tested it as my Bentley manual tells me and I think it was bad so I replaced it salvaged from the internet wrecking site sj from N.Y. and plugged it in and there is no difference so I bought new distributor cap and rotor, cables and plugs and spent some time, timing it no luck adjusted the idle (without a tack ) and now have broken spirits and wallet. Any suggestions
[/b] |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Thu Feb 17, 2005 5:06 am Post subject: |
have you went through the hoses to see if you have a vac leak? how old is the fuel filter? _________________ My Art:
http://www.instagram.com/flynn8552/ |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3343 Location: Talos IV, Piedmont Arizona
Posted: Thu Feb 17, 2005 5:19 am Post subject: |
If your AFM is slamming shut when the engine is cranking you may have the dredded sucked valve seat. check your intake valves for 1 standing proud(sticking out mone than thr others) If this is so it's new head time. GOOD LUCK bill _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
Randy in Maine Samba Member
Posted: Thu Feb 17, 2005 6:45 am Post subject: |
Start by looking for vacuum leaks, poor electrical connections, checking the fuel pressue as per your Bentley, and doing a compression test as per the Book of Ratwell Verse 1.1 http://www.ratwell.com/technical/FAQ.html
Post those findings here. And then start calling around to see who can do a leakdown test in your area. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Feb 17, 2005 10:16 am Post subject: |
I'd be willing to bet that when it stalled, it backfired back through the intake and blew a hose off somewhere. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
