CHT Nirvana (cylinder head temperature) gauge/sender FAQ
Page: Previous  1, 2, 3 ... 13, 14, 15, 16, 17  Next
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Fri Feb 26, 2016 9:55 am    Post subject: Re: CHT Nirvana Reply with quote
I think that's what DD was getting at when they say to only use the DD sender. running copper wire from a junction at the sender in the back isn't going to work well. You can get thermocouple wire all day long on eBay fairly inexpensively.., although the Chinese TC connectors are highly suspect, I would recommend getting Omega K-type instead of eBay China for those.
I never could get my poor man's DD to work right, it would fluctuate and indicate too low with engine running. Would only indicate the correct temp with engine off.
Robert in Memphis
1971 Riviera small pop-top
Engine rebuild thread
Fuelly MPG and maintenance stats
1641cc | CB cheater cam | H30/31 | 205T SVA | FF oil | everything else stock
FAA A&P
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Feb 26, 2016 10:54 am    Post subject: Re: CHT Nirvana Reply with quote
Only the oil temp sender is the VDO one.
It cost about the same money to do it correctly.
scrivyscriv
Samba Electrician
PostPosted: Fri Feb 26, 2016 11:04 am    Post subject: Re: CHT Nirvana Reply with quote
Randy in Maine wrote:
... to do it correctly.
A thermocouple wire is a thermocouple wire is a thermocouple wire.. its going to be an industry standard TC wire. I can only speculate on which exact type but it's pretty likely either a J type or a K type, I doubt at their price and performance point it's anything more exotic.
there's not really any reason to insist that buying their exact part is the 'correct' way to wire a gauge in. it might be the preferred way to do it, full stop.
Robert in Memphis
FAA A&P
pittwagen
pittwagen is offline
PostPosted: Fri Feb 26, 2016 3:49 pm    Post subject: Re: CHT Nirvana Reply with quote
Well let me ask this question. Can anyone say "from personal experience" that they connected the DD gauge to the VDO wiring and it worked or it didn't?
I currently have the VDO setup in my bus and other than doing the calculation when ambient temps are over 70 deg or 75 deg, whichever it is, I have almost 5 years of info to know what is normal for my bus and what is not. Rewiring, given my particular setup, is not easy. I do not use the thermocouple under the plug. Mine is wired like the Oranje Trophy bus.
So is it 70 or 75 that one adds or subtracts a degree from to get the actual CHT temp with the VDO? I have seen both reported on this forum. It would be nice if someone could nail that one down with factual evidence too.
Tcash
Tcash is offline
PostPosted: Tue Mar 22, 2016 4:29 pm    Post subject: Temp II sensor - Matching Gauge Reply with quote
Continued from:
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
mrcool wrote:
I am looking for a gauge that will work with a temp II sensor. Has anyone found one, or found a gauge that can be calibrated? I much rather use the ports that are on the side of the heads than using a Spark plug adapter ring.
I actually have a 1983 Vanagon but with a CV Type 4 Air Cooled motor, so same team guys Very Happy
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Wed Mar 23, 2016 11:48 am    Post subject: Re: CHT Nirvana Reply with quote
Part of what we pay for when we buy the DD gauge is the 14' thermocouple wire that the VDO gauge lacks. It is because of this that you have to compensate manually when using the VDO setup. Since you're used to your bus temperature trends, your money is probably better spent elsewhere.
An email I received from the VDO help desk:
VDO technical service email support wrote:
The sender is a K type thermocouple and it is cold junction compensated. The length of the thermocouple wire is 12 inches before it goes to regular copper wiring.
This means you'll technically be able to use the DD gauge, but it will give the exact same reading, plus or minus a few degrees.
Here's why:
The Tref point on the DD gauge is inside the gauge itself. On the VDO gauge, the Tref point is 12" from the sender end. The entire function of K-type thermocouples is dependent on knowing Tref and comparing it to the voltage change at Tsense. If Tref is not measured or controlled, your gauge will only be as accurate as the temperature fluctuations at Tref.
In plain English, this means the answer to your question is yes* *The catch is that it won't be any more accurate. VDO did not get back to me with WHAT temperature they use for Tref. So we can't answer that one for sure. Dakota Digital was far more specific in how they know Tref:
Dakota Digital wrote:
Because the thermocouple only measures the temperature difference, the gauge has a temperature sensor so that the temperature at the gauge end of the thermocouple wire is known.
www.airschooled.com
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
gereonb
gereonb is offline
PostPosted: Thu Sep 29, 2016 8:18 am    Post subject: Re: CHT Nirvana Reply with quote
4-channel K-type Temperature Gauge = $32
4 * 14mm Spark Plug K-Type Thermocouples 12ft = $24
Now THAT is CHT Nirvana !
scrivyscriv
Samba Electrician
PostPosted: Thu Sep 29, 2016 8:27 am    Post subject: Re: CHT Nirvana Reply with quote
Just a heads up some gauges cannot handle a grounded thermocouple, which is what the spark plug ring is.. Any direct metal contact to the engine will ground the thermocouple and the gauge circuit. My poor man's Dakota digital would not read correctly with the engine on because it's not set up to use a grounded input. Which is why you see things like insulated EGT probes. A reciprocating engine aircraft CHT uses a similarly insulated CHT probe as well
Robert in Memphis
FAA A&P
SGKent Premium Member
SGKent is offline
PostPosted: Thu Sep 29, 2016 9:54 am    Post subject: Re: CHT Nirvana Reply with quote
Based on threads in other forums from some who are engineers - about 70F
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing it right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
Bus Engine Cooling Issues? https://kentcomputer.com/77VW/BusEngineCooling.pdf
aerosurfer
aerosurfer is offline
PostPosted: Thu Sep 29, 2016 10:06 am    Post subject: Re: CHT Nirvana Reply with quote
I have been very happy with my home made CHT setup using the poor mans DD thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=592584&highlight=poor+mans
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
Dangermouse
Dangermouse is offline
PostPosted: Mon Dec 05, 2016 7:34 pm    Post subject: Re: CHT Nirvana Reply with quote
I like my VDO CHT gauge but have experienced my fair share of mussed up, ovalled out ring senders which get distorted on installation and removal. I thought I'd try and do better this time so here's something I tried. In my experience, the 14mm VDO ring sender doesn't easily fit over the threads of the spark plug out of the packet and needs to be made just a hair bigger to slip over the threads. A small grinding stone on a dremel tool works well for this -
In the past I've found that the soft metal of the sender (copper?) tends to want to distort when you bend it up so to keep everything held in place and flat I used a 14x1.25 spindle nut I found on eBay for a couple of bucks. With this threaded down against the sender and sandwiching it tightly against the plug I was able to reshape it with a small drift without affecting the close fit of the ring portion around the plug threads. I think I could have gotten an even closer fit around the body of the plug if I had ground down the crimped area just a little bit.
This made for a clean and distortion-free installation of the plug and cht sender; this is how I will be doing this in future. Maybe it'll be of use to somebody out there.
Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you.
Lil Lulu
Lil Lulu is offline
PostPosted: Mon Dec 05, 2016 9:29 pm    Post subject: Re: CHT Nirvana Reply with quote
Dangermouse- I did the same thing to my DD ring sender. It has lasted for 6 years now with no distortion and no leaks. It helps to form it to the plug before installing and then insert it in the hole as a unit. I think DD will sell a separate ring if it does distort.
'65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles
gintaras
gintaras is offline
PostPosted: Tue Dec 06, 2016 6:12 am    Post subject: Re: CHT Nirvana Reply with quote
Well, I routed my TC wire under the intake flange, in-between the tin and head, I think I am grounding out and getting the temperature of where the wires are hitting the tin, because it is almost always around 180-200
In order to fix this, I would need to remove the left side intake side, and insulate the wires where they touch the tin..
1979 Deluxe Westy in Mexico Beige
pierrox
pierrox is offline
PostPosted: Mon Jan 22, 2018 10:34 am    Post subject: Re: CHT Nirvana (cylinder head temperature) gauge/sender FAQ Reply with quote
Thanks for this thread!
Just got mine in the post this weekend, that's pretty exciting!
How did you guys install it in general? Run the sender from under the plug through the tinware via the plug hole? Or did you route it under the tinware and exited somewhere... where?
Our bus in on Instagram, and soon it will be on the road too!
instagram.com/biencuitbus
View user's profile Send private message Instagram Classifieds Feedback
Wildthings
Wildthings is online now
PostPosted: Mon Jan 22, 2018 10:44 am    Post subject: Re: CHT Nirvana (cylinder head temperature) gauge/sender FAQ Reply with quote
I wouldn't run it through the plug hole because that would make it vulnerable to damage when you were removing and installing the plug. I added an extra hole in the tin coupled with a rubber grommet.
Randy in Maine
PostPosted: Mon Jan 22, 2018 10:48 am    Post subject: Re: CHT Nirvana (cylinder head temperature) gauge/sender FAQ Reply with quote
My sender clips to the one of the casting fins at the head and then exits in its own little hole (with a grommet) in the tinwork. Been here? It uses a little spring clip from a door or a "binder clip" that has been ground down on a grinding wheel.
http://www.germansupply.com/home/customer/home.php?gspage=customer/main/tech/cht/cht_install.tpl
CarlosZ
CarlosZ is offline
PostPosted: Mon Jan 22, 2018 11:29 am    Post subject: Re: CHT Nirvana (cylinder head temperature) gauge/sender FAQ Reply with quote
Iíve had the sender ring installed for over a year and finally hooked up the rest of the wiring and gauge prior to BBB 2018.
I installed the sender by cutting a wedge into the head by plug #3 and clipping the wire to a head fin. Not sure where the clip came from, might be piece of the interior but does the job. I routed the sender wire between two tin pieces. The sender has a protective sheath that I hope will prevent wear. Iíve removed the plug about 10 times and no ovaling or movement. The ring is sitting pretty on the head. Iíd suggest you go the the cut in the head and clip for best results.
furgo
furgo is offline
PostPosted: Mon Jan 22, 2018 2:15 pm    Post subject: Re: CHT Nirvana (cylinder head temperature) gauge/sender FAQ Reply with quote
Quick question to those who've installed the sender: do you need to remove the crush washer/gasket of the spark plug when using the ring sender?
In other words, is the ring sender effectively replacing (and acting as) the gasket?
'79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Randy in Maine
PostPosted: Mon Jan 22, 2018 2:21 pm    Post subject: Re: CHT Nirvana (cylinder head temperature) gauge/sender FAQ Reply with quote
I leave the spark plug washer on.
CarlosZ
CarlosZ is offline
PostPosted: Mon Jan 22, 2018 5:29 pm    Post subject: Re: CHT Nirvana (cylinder head temperature) gauge/sender FAQ Reply with quote
I've removed the plug washer.
Page 14 of 17
