petevdub Samba Member
Joined: January 01, 2005 Posts: 205 Location: Toronto, Canada
Posted: Wed Jul 23, 2014 6:09 pm Post subject: |
Bruce wrote: |
petevdub wrote: |
This is what I gather from reading this thread. Stock, the solenoid and bulb are wired in series to each other fed from the single post/connection and ground through the body mount to complete the circuit.
Not true. The bulb and solenoid are wired in parallel. |
Good to know. Thanks. _________________ '72 super
'65 21w
'52 split 11C |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Thu Jan 22, 2015 3:43 am Post subject: |
quick question...
so the black and white wire is power for the semaphore solenoid...
and the bulb?
when making a separate supply for the bulb so it can flash, could the blue wire (usually for the dash light) be disconnected and re-used for bulb power to save running an extra wire, and then I can deal with the dash light in a different way under the hood? |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Thu Jan 22, 2015 2:02 pm Post subject: |
Yes. I ran the power from the flasher backward up the blue wire to the dash light, then on to the sema bulb. Then ground it out there. _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
Posted: Thu Jan 22, 2015 5:19 pm Post subject: |
perfect. thanks sir. much appreciated |
Low Bräu Samba Member
Joined: December 12, 2003 Posts: 346 Location: Merritt Island, FL
Posted: Fri Oct 02, 2015 9:49 am Post subject: |
I figured you guys, and girls, would appreciate these flashing 6 volt festoon LED bulbs that work in Semaphores. I stopped by a friends house the other day and he had just installed a set on his 55 beetle. I was impressed enough to buy a set for my 52. With shipping to the US they are were just over $50. Super bright even in the Florida sun and the good thing is no extra wiring or relays involved. Here is a link to the seller and a video on the Tube. I have no affiliation with the seller just thought someone here might be interested.
Bulbs:
http://www.dynamoregulatorconversions.com/flashing-indicator-bulbs-shop.php
Video:
https://www.youtube.com/watch?v=yJLwsODIRho&feature=youtu.be _________________ Independent German Auto
671 Fern Drive
Merritt Island, FL 32952
(321) 449-4665
Specializing in repair and maintenance for Porsche, BMW, Mini, Audi, and Volkswagen.
1952 Standard Beetle
1960 SO-23 Westfalia
1961 L-380 Turkis Deluxe Beetle
1985 Vanagon Country Homes Camper (work in progress - EG33 swap)
tfmichie Samba Member
Posted: Sat Oct 03, 2015 1:38 am Post subject: |
I have them too... they are just excellent...!! Just change the bulbs and done! |
0nebadbug Samba Member
Joined: October 01, 2009 Posts: 1087 Location: Rockford, Illinois
Posted: Sat Oct 03, 2015 7:23 am Post subject: |
Thanks! Order placed! ...And both of their signal buzzers gizmos too.
Can't tell you how many times people pull up next to me at stop lights, parking lots, drive thru's etc... saying Hey, there some weird yellow thing sticking out the side of your door. ..And then of course you have to explain what they actually are for 10 minutes... _________________ ::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 ::: |
kuta Samba Member
Joined: June 08, 2012 Posts: 95 Location: Melbourne, Australia
Posted: Sun Oct 04, 2015 2:28 am Post subject: |
I need a set, what size bulb are they to fit the semaphore? |
Posted: Sun Oct 04, 2015 5:24 am Post subject: |
Should be 31 mm with the 7mm bullets on the ends. It says they are the "Bosch Style" and the Lucas ones are 36mm. Didn't even notice the signal buzzer gizmo or the LED headlights. Just might have to make another order. _________________ Independent German Auto
671 Fern Drive
(321) 449-4665
1985 Vanagon Country Homes Camper (work in progress - EG33 swap) |
joshbuchan Samba Member
Joined: April 12, 2007 Posts: 712 Location: victoria bc canada
Posted: Mon Oct 05, 2015 7:47 pm Post subject: |
Mine....
https://instagram.com/p/52O3zqoNnC/
Used 2 old SWF brown 55-59 relays and gutted them/soldered in new solid state goodies. Wiring was easy, using a Bosch red tip semi switch. Made hearts blink too and own LED clusters for brake/running. |
empiracer Samba Member
Joined: December 17, 2002 Posts: 1098 Location: Issaquah / Seattle, Wa.
D-train Samba Member
Posted: Tue Oct 13, 2015 2:58 am Post subject: |
I'm running the 6v flashing leds too, but found when I use the parkers or headlights they didn't work too well or if at all. Seemed too much power drained to the other globes.
Still need to check the voltage going to them when the lights are on. Only supposed to use 5w for them to work. _________________ shiny paint doesnt make it worth any more |
vwovalguy Samba Member
Joined: December 12, 2001 Posts: 462 Location: HOCKEY, MAPLE SYRUP AND RUSH
Posted: Tue Oct 13, 2015 9:31 pm Post subject: |
I have one of these NOS in the box. I won't be using it.......
SAMBA VAN MAN wrote: |
So i have got my N/O/S SWF Blink motor anyway i thought i would give the case a polish, and while it was off i thought i would take some photos of the inside just so you guys can see what is inside.
Russ Samba Member
Joined: January 12, 2003 Posts: 1560 Location: Langley B.C.
Posted: Fri Oct 16, 2015 4:00 pm Post subject: |
these were super simple to install from my understanding, my ex did them herself and said piece of cake _________________ Cruiser pedals for sale (see my ad's)
55 hardtop finally finished
65 beetle done:) |
igtoth Samba Member
Joined: May 09, 2006 Posts: 385 Location: Ribeirão Preto, SP, Brazil
Posted: Fri Jan 15, 2016 11:59 am Post subject: |
Here is a video i shot of my N/O/S SWF Blink motor, i set it up as a test rig for now just to make it easier to show you guys the internals.
http://youtu.be/L_2qLwMrCaA |
Nice and crazy! _________________ 1957 Typ 113 - Polarsilver
1959 Typ 113 - Flint Grey
1975 Typ 221 - Last yr Brazilian Split Window
Ighor Toth |
fabbe Samba Member
Posted: Sat Feb 06, 2016 3:18 am Post subject: Re: Flashing semaphores...? |
with led
Posted: Sun Feb 07, 2016 12:40 am Post subject: Re: Flashing semaphores...? |
fabbe wrote: |
with led
R they 6v ones? I have them too but when any of the other lights are on they don't seem to work. Even using the brake lights they play up. Pretty annoying.. _________________ shiny paint doesnt make it worth any more |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Sun Feb 07, 2016 3:24 am Post subject: Re: Flashing semaphores...? |
Measure the voltage at the semaphore when you have the other guilty lights on. _________________
fabbe Samba Member
Posted: Sun Feb 07, 2016 12:08 pm Post subject: Re: Flashing semaphores...? |
D-train wrote: |
R they 6v ones? I have them too but when any of the other lights are on they don't seem to work. Even using the brake lights they play up. Pretty annoying.. |
no problem for me |
igtoth Samba Member
Posted: Sun Apr 02, 2017 8:44 am Post subject: Re: Flashing semaphores...? |
Found this one, seems nice :
Ighor Toth |
