How did you deal with your window seal rust?
Vespagetti
Vespagetti is offline
PostPosted: Tue Mar 01, 2005 12:09 am    Post subject: How did you deal with your window seal rust? Reply with quote
I have a couple of bubbles and a perforation along the window seals. What's the best way to deal with this? I'm pretty good when it comes to body work but I'm reluctant to undertake this. Do I have to pull the windows off? Should I just leave it to the pro? If let the shop do it, I guess I might as well do a complete paint job....
Any input appreciated...
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Mar 01, 2005 11:04 am    Post subject: Reply with quote
Been here?
http://homepage.mac.com/ratwell/78_Westy/PhotoAlbum35.html
It will give you an idea....
Vespagetti
PostPosted: Tue Mar 01, 2005 12:25 pm    Post subject: Reply with quote
Randy in Maine wrote:
Been here?
Great link, thanks! I just have to find some how to's....looks way beyond what I can do though:
VANAGON L DIESEL
VANAGON L DIESEL is offline
PostPosted: Mon Mar 21, 2005 11:03 am    Post subject: Reply with quote
hello
well you got the problem to ?. this is whst i did,with some sucsses. not great but good.
i first taped along the seal ,then i took a strong plastic knife and lifted on the seal held it up, sanded it down with a drummel tool, and then filled with bondo very small amount then moved on to the nexted spot till i was done painted it my self so so not bad better. take your time lots of time . good luck
View user's profile Send private message MSN Messenger Classifieds Feedback
CF
CF is offline
PostPosted: Mon Mar 21, 2005 4:03 pm    Post subject: Reply with quote
PULL THE GLASS . SAND AND CLEAN THAN POR 15 THAN BONDO , PRIME ANDS PAINT. Very Happy
walrus
walrus is offline
PostPosted: Wed Oct 26, 2005 11:33 pm    Post subject: Reply with quote
POR makes a filler like Bondo but better. I believe bondo will absorb moisture.
1987 Syncro west. conversion
1991 Jetta gli
Captain Pike
Captain Pike is offline
PostPosted: Thu Oct 27, 2005 4:50 am    Post subject: Reply with quote
Bondo must be sealed,it can wick moisture. Pull the window.
Whisper__"If You Build It_______It Will Run"
All Current
1959 panel van, 1966 single cab. 73' 181. 91' H6 Vanagon(Under construction).
bself
bself is offline
PostPosted: Mon Oct 31, 2005 9:28 pm    Post subject: Reply with quote
vespagati, i'm in the same boat you are except the rust spot in the lower corner of the passenger side windshield has decided to give way. Just as the rains move in to the Pacific NW and shroud us in moisture for the next 8 months. I bought some clear sealant stuff the other day which was not very effective so I'm calling body shops this week as I'm in no position to do the work myself. I've got a nice size puddle on the floorboard which is not good.
Not trying to hijack your thread but can anyone out there in Samba Land recommend a body shop in Portland, OR with experience with VW Westy's?? I've come up with a short list of establishments but that's just browsing this site and the yellow pages. Any input would be appreciated.
VW Logo 1987 VW Vanagon Westfalia SBX EJ25
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
[email protected]
jmp@ncounty.net is offline
PostPosted: Tue Nov 01, 2005 7:41 pm    Post subject: Reply with quote
The fiberglass embeded filler by evercoat does not wick water and is water proof works well with Por15.
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Nov 01, 2005 9:32 pm    Post subject: Reply with quote
I've dealt with this sort of stuff for decades. The repair depends on a few things. For minor stuff go the POR15 route and lift the seal. But it depends. If it is worse under the seal, you may need to pull the window and do more work.
You're in San Diego, me too. Let me see it. This weather we are having for the next days is perfect to fix this. But, it depends. If real bad, you may need to go to a body shop.
Sometimes I have ended up painting the whole front of the van, if it is bad.
You need to do this right or you will have problems again later. Most likel worse.
-Walt...
