Stanw3 Samba Member
Joined: September 26, 2003 Posts: 1077 Location: Albuquerque, NM
Posted: Sun Mar 06, 2005 8:24 pm Post subject: 61 walk thru - One year only seats? |
Seems like someone once told me that 61 walk-thru seats were a one year only size - anyone know for sure?
Thanks |
PARTSSCOOT Samba Member
Joined: March 04, 2004 Posts: 94 Location: Africa Hot AZ
Posted: Mon Mar 07, 2005 7:23 am Post subject: |
I've got a 60 that I just bought seats for. I believe the seats from 57-62 are the same. I had a hell of a time finding some. They differ from the later ones in that they don't have any sliders and the bottoms are curved to fit the floor. I just went through all this myself recently so if you have any questions like brackets,mounting,etc, just ask. I'll try to answer what I know. |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Mon Mar 07, 2005 7:27 am Post subject: |
I thought 58 through 61 were the same seat. |
Posted: Mon Mar 07, 2005 7:46 pm Post subject: |
I was thinking of the years it was between, oops. TimGud's right 58-61. |
Clara Samba Member
Posted: Tue Mar 08, 2005 10:23 am Post subject: |
FWIW, most of 62 for LHD has a one yearish only drivers seat. it slides, and the slider adjustment is on the right side of the seat in the aisleway. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
The Pinstriper Samba Member
Joined: June 21, 2013 Posts: 13 Location: Winter Springs
Posted: Tue Sep 12, 2017 6:04 pm Post subject: Re: 61 walk thru - One year only seats? |
Is the driver seat back supposed to be taller than the passenger? |
Stocknazi Samba Member
Posted: Wed Sep 13, 2017 5:12 pm Post subject: Re: 61 walk thru - One year only seats? |
The Pinstriper wrote: |
The taller backrest is 63-67. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Thu Sep 14, 2017 4:16 am Post subject: Re: 61 walk thru - One year only seats? |
I have a early 61 with a tall driver seat.. |
Posted: Thu Sep 14, 2017 4:23 am Post subject: Re: 61 walk thru - One year only seats? |
BulletBus Samba Member
Joined: August 17, 2005 Posts: 1276 Location: Panama City Beach
Posted: Thu Sep 14, 2017 5:01 am Post subject: Re: 61 walk thru - One year only seats? |
You have the wrong seat. But I bet it's more comfy! _________________ 53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen. |
Posted: Thu Sep 14, 2017 5:43 am Post subject: Re: 61 walk thru - One year only seats? |
It's comfortable.. I wonder how it's not the right one but fits on the track properly! |
mg6770 Samba Member
Joined: July 26, 2005 Posts: 843 Location: North Shore CamPbodia
Posted: Thu Sep 14, 2017 5:49 am Post subject: Re: 61 walk thru - One year only seats? |
Does your driver seat back have the hooks that connect to the w/t bulkhead? I've never seen an early w/t with a back tall like that. My guess is with Vince, I think it's incorrect but looks comfy! _________________ Phil 4:13 |
Posted: Thu Sep 14, 2017 5:53 am Post subject: Re: 61 walk thru - One year only seats? |
No it does not.. the seat also adjusts! |
sled Samba Member
Posted: Thu Sep 14, 2017 6:14 am Post subject: Re: 61 walk thru - One year only seats? |
you have the wrong seat as well as the wrong slider rails on the seat pedestal...there should be none. _________________ drive your split. |
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 899 Location: Las Vegas, NV
Posted: Thu Sep 14, 2017 6:53 am Post subject: Re: 61 walk thru - One year only seats? |
So it sounds like at some point in the life of your bus someone added a drivers seat and the correct lower track from a 1962 bus. An early 61 should not have this drivers seat. _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Thu Sep 14, 2017 6:56 am Post subject: Re: 61 walk thru - One year only seats? |
It's definitely the correct seat bottom for that track. I was told that it was a three month only. |
Posted: Thu Sep 14, 2017 7:13 am Post subject: Re: 61 walk thru - One year only seats? |
I am not disputing that it is not the correct seat bottom for the track. I think what we are saying is that it is not correct for your bus if your bus is an early 61. Someone added that track and seat from a 62 when they could not find the correct seat. It certainly works just fine and 99% of VW people would have no idea it is incorrect. Here is the correct drivers seat that should be in your bus.
https://www.thesamba.com/vw/classifieds/detail.php?id=2091566 _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Thu Sep 14, 2017 7:21 am Post subject: Re: 61 walk thru - One year only seats? |
Here is a copy of the progressive refinements VW book and page which shows exactly when this change occurred. It looks May 6, 1961 beginning with chassis number 770862. If you bus was built before that date and chassis number then it should have the fixed front drivers seat.
CaLiBus Samba Member
Posted: Thu Sep 14, 2017 7:36 am Post subject: Re: 61 walk thru - One year only seats? |
Notice the bottom right side. Small metal hole tab to secure the seat. Your bus is missing this |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Thu Sep 14, 2017 7:55 am Post subject: Re: 61 walk thru - One year only seats? |
Tue Apr 28, 2009 11:57 am
Lind wrote: |
House wrote: |
Does anybody have the chassis number range for the "62 only" seats?
I would imagine it is not exactly consistent with the 1962 model year...? |
you are correct. the '62 walkthrough started early in the '62 model year. I don't know exactly when, but it is certainly later than the chassis number that is given in progressive refinements detailing the change (yes, PR is not always correct). a friend of mine has a '62 walkthrough with the earlier seats. (august '61 production, later taillights and turn signals, etc.) |
ronjonlasvegas wrote: |
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
