Mike Edwards Samba Member
Joined: November 17, 2003 Posts: 44 Location: Charlotte, NC
Posted: Tue Mar 08, 2005 3:32 pm Post subject: Clutch TOB Operating Shaft Bushings |
I recently removed the clutch TOB operating shaft on my 73 Thing. I ordered a bushing kit because I mangled the old one during remomal. Notice how the shaft had two rubber bushings (or seals) and a plasic bushing.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=195527
The kit I received had only one brass bushing. Note how much thicker the walls are than the original (on the left). Also, it has what looks like an insert. Doesn't seem like this one will fit over the shaft.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=195528
Has anyone had any experience with this? Did I just get the wrong part? I know that sometimes replacement parts can be different from original. For example, maybe this new thicker bushing is designed to replace the rubber and plasic pieces that came off the original.
Any insight appreciated.
Thanks,
Mike |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1681 Location: Nebraska
Posted: Wed Mar 09, 2005 5:51 pm Post subject: |
I think you got the wrong part. |
Posted: Thu Mar 17, 2005 2:56 pm Post subject: |
Yeah, I think my mistake was ordering the "bushing kit". I was able to find the correct parts by ordering individual part numbers.
113141711A
Clutch Op Shaft Bushing Right
113141707C
Clutch Op Shaft Bushing Left
N012416 1
Lockring 16x1
113141721A
Rubber Bush, Op Shaft |
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 557 Location: Bucks County, PA
Posted: Thu Feb 24, 2022 4:20 pm Post subject: Re: Clutch TOB Operating Shaft Bushings |
I need the brass bushing that was mentioned above. If I remember correctly, it goes inside the plastic bushing with the screw hole? I took it apart about a year ago and I’m not quite sure. I don’t see it in the parts diagram, but it is shown in a listing on thingparts.com for a used set of clutch shaft bushings. Anyone have a number for this? Is it in the diagram and I just don’t see it?
Photo from things parts.com:
_________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17273 Location: Left coast, Canada
Posted: Sat Feb 26, 2022 7:02 am Post subject: Re: Clutch TOB Operating Shaft Bushings |
The part you're calling a "brass bushing" is neither brass, nor a bushing. It is aluminum that is gold anodized. It is a sleeve that goes into the trans case, and inside that goes the factory plastic bushing.
Strangely, it is not shown in the exploded view diagram you posted. _________________
germansupplyscott Samba Member
Posted: Fri Mar 04, 2022 1:57 pm Post subject: Re: Clutch TOB Operating Shaft Bushings |
The thick-walled bushing looks like the one made by Weddle. It replaces the hard plastic bushing that was used originally, that also has the two rubber boots on either end.
According to Weddle it's OK to have the bushing without the seals, but I wish they'd make one with the steps in it for the seals. They are used on the Bus transaxles and late Type 1 units. _________________ SL |
