volksaddict Samba Member
Posted: Sat Mar 12, 2005 6:17 am Post subject: Where's the tranny noise coming from? |
How do I know if the whine from my rear end is the trans or rgb's? A steady howl noticable at about 40 mph, increasing in volume with speed. Sounds like it's out of gear oil but it's not. |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Sat Mar 12, 2005 6:54 am Post subject: |
Block up the back of the bus and turn the wheels and listen. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
super64 Samba Member
Joined: February 08, 2004 Posts: 31 Location: Kansas city
Posted: Sat Mar 12, 2005 8:39 pm Post subject: noise |
Does the noise go away if you push the clutch in? If it does or make a little less noise then its your mainshaft bearing, If thats your problem better get it fixed now , If that bearing lets go it will whipe out 3rd ,4rth and the case,and maybe more,I build transaxles for a living |
KombiMonster Samba Member
Joined: April 17, 2001 Posts: 2751 Location: Central Cal.
Posted: Sun Mar 13, 2005 8:11 pm Post subject: |
I think I'll be pulling my motor out this coming weekend..because I think my throw-out bearing is going out...I hear a little noise like a squeeky belt once in awhile now....Could this be anything else?.....(just happend today) _________________ FOOK CANCER
*WANTED* |
Posted: Sun Mar 13, 2005 10:07 pm Post subject: noise |
I would try that 1rst ,If you still hear it after that ...Mainshaft bearing ? |
Posted: Mon Mar 14, 2005 5:31 am Post subject: |
Noise seems to stay the same whether it's driving or coasting, clutch in or out. I didn't get to jack it up and run it this weekend, I was painting my ghia. I'll see if I can try that this week.
Throwout bearing noise? Hell, I drive those till they fly apart! |
Jeff Power Samba Member
Joined: October 13, 2004 Posts: 1170 Location: with any luck, in my garage building bass guitars.
Posted: Mon Mar 14, 2005 6:12 am Post subject: |
I have the same type of noise, but only in 4th, and only from about 35mph to 40mph on acceleration. Then it goes away. Also sometimes after long periods of 50mph or so it goes away completely. What the heck is that? _________________ I build complete Westy Style camping interiors check them out here > www.rjcampers.com
Check out my basses here www.ellabasses.com
jerry wrote: |
Nothing says "I love busses" more than picking up a mouse turd filled with horse hair seat padding |
Posted: Mon Mar 14, 2005 10:03 am Post subject: Re: noise |
super64 wrote: |
I forgot to mention...I only hear the noise when I engage the clutch!..(when I'm going slow enough to hear it)...The tranny is a rebuilt unit with about 6,000 miles on it...I'll be leaning (hope'n) its just the throw-out bearing.. _________________ FOOK CANCER
*WANTED* |
busded Samba Member
Posted: Mon Mar 14, 2005 4:32 pm Post subject: |
Hey super64, Mine was making that noise and I just started having trouble with 4th gear slipping, mainly uphill. 3rd is starting to do it now too a little. Too late for my tranny? |
Posted: Tue Mar 15, 2005 10:37 pm Post subject: |
ok..I pulled the motor out tonight and found my throw-out bearing being held on with only one clip! ...the other clip was in the starter cave...So I guess it wasn't too bad...the bearing showed some wear on the rim..so I'll be replacing it.... _________________ FOOK CANCER
*WANTED* |
Renato Assis Samba Member
Joined: March 31, 2011 Posts: 12 Location: Brazil-Rio de Janeiro
Posted: Sat Oct 19, 2013 3:30 pm Post subject: |
Hi everyone.
Sorry for resurrecting this thread, but I have a similar problem.
Much like the case of the OP, the whine coming from the rear end of the bus starts at about 40mph and gets louder as speed increases.
If I push the cluth or lift off the gas the noise stops.
Is my mainshaft bearing doomed? |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Sat Oct 19, 2013 7:01 pm Post subject: |
I'm betting your ring and pinion is worn. Change the gear oil and you might add some silence. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Mon Oct 21, 2013 6:05 pm Post subject: |
Sounds like chipped / broken teeth on the pinion gear... whines under any load. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Tue Oct 22, 2013 7:59 am Post subject: |
Thanks for the reply guys!
I'll have my trans checked as soon as possible. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Oct 22, 2013 8:50 am Post subject: |
Renato Assis wrote: |
the longer you wait, the faster it will be possible _________________ regards
Uli
