srsummers Samba Member
Joined: December 06, 2013 Posts: 6 Location: Goodyear, AZ
Posted: Fri Dec 04, 2015 1:57 pm Post subject: Installing Door Hinge Pins |
I ordered the Eastwood puller, it worked well, esp for the price. It made a small mark on the door but I'm in the process of doing the body work now, so no biggie. I'm getting ready to install the new pins. Do drive them in with a non-marring hammer? Seems like a really tight fit...which is good. |
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Fri Dec 04, 2015 3:02 pm Post subject: Re: Installing Door Hinge Pins |
Do you have link or a picture of the puller you used? |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Fri Dec 04, 2015 3:16 pm Post subject: Re: Installing Door Hinge Pins |
I used a rubber mallet on mine for most of the way and then for the last little bit used the old hinge pin inserted into the top of the pin to knock it in the rest of the way. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri Dec 04, 2015 3:38 pm Post subject: Re: Installing Door Hinge Pins |
Dake wrote: |
X2 My drivers side door is in need of replacement pins as well. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Jmiddle204 Samba Member
Joined: September 06, 2011 Posts: 83 Location: Scottsdale, AZ
Posted: Fri Dec 04, 2015 4:45 pm Post subject: Re: Installing Door Hinge Pins |
Search the feedback on the Eastwood tool. Some have commented on challenges with using that specific tool.
I have mine currently available for rent (shameless plug).
http://www.thesamba.com/vw/classifieds/detail.php?id=1764039
James _________________ '62 Vert |
Posted: Fri Dec 04, 2015 5:16 pm Post subject: Re: Installing Door Hinge Pins |
James that is quite shameless. Lol.
I'll keep you in mind. _________________ I have learned over the years.
Buy Once, Cry Once!
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Fri Dec 04, 2015 8:38 pm Post subject: Re: Installing Door Hinge Pins |
I'd like to tackle this job, but worry about what size pin to install. First oversize? Second oversize? How do you "ream" out the hinge to accept either one? How do you know you've reamed enough so that you don't go pounding in the new pin and it will only go halfway?
Anyone done this job? What was your experience?
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
