M_atthewanderson Samba Member
Joined: January 25, 2005 Posts: 288 Location: Seattle
Posted: Thu Mar 24, 2005 12:12 am Post subject: taking engine out anything i should check or do while out |
Im taking the engine out of my 1980 2.0 fuel injected Vanagon to replace one head with a broken intake valve on cylinder 2. Just wondering if after 25 years I should do anything while the engines out. Check seals, wiring, gaskets, anything at all. _________________ 1980 2.0 Sunroof Vanagon |
Randy in Maine Samba Member
Posted: Thu Mar 24, 2005 7:20 am Post subject: |
1) Check crankshaft endplay.
2) If it is leaking oil at the front main, replace that seal. Same with the rear seal. If you have to cart the engine down to the VW shop to have them do this 1&2, it is worth it.
3) Change out any fuel and vent lines that you can only get to with the engine out. Clamp them.
4) If you have to remove the clutch and flywheel, index them so that it goes on the way it came off.
5) General cleaning and painting. A day spent sandblasting and painting your tinwork is time well spent. You want that engine to as clean as it is ever going to be.
6) Make sure the heaters are working as good as they can. Check out the operation of the thermostat.
7) Replace the pushrod seals if they are leaking.
8) Never disassemble the fan for painting.
9) Replace all of the vacuum lines since they are all exposed anyway.
10) If the oil cooler seals are leaking, replace them and torque carefully.
11) Replace the engine to body seal if it is lame.
12) Clean up the tail light and side marker lights wiring.
13) Inspect and clean up the battery boxes.
I printed out ratwells engine removal in 20 easy steps at the baywindow forum. Very helpful and don't be afraid to make some notes on it and label everything. I clean all of the bolts tht I can on the bench grinder just because. |
