wcfvw69 Samba Purist
Posted: Fri Jan 19, 2018 8:40 pm Post subject: Re: Home-made fuel pump rebuilding jig |
kreemoweet wrote: |
wcfvw69 wrote: |
Preloading also helps line up the diaphragm with the bolt holes. |
There's no reason not to have all the bolts installed, but not tightened all the way, before preloading. |
I agree and slightly preloading the diaphragm allows the bolts to line up so much easier. _________________ Contact me at [email protected]
The Samba member since 2004.
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Sun Oct 14, 2018 12:28 pm Post subject: Re: Home-made fuel pump rebuilding jig |
This^ looks like it was made from something else (that's how professional it looks if completely-from-scratch homemade).
What is it made from, if not completely homemade? _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Sun Oct 14, 2018 12:39 pm Post subject: Re: Home-made fuel pump rebuilding jig |
scottyrocks wrote: |
What is it made from, if not completely homemade? |
http://vwparts.aircooled.net/Fuel-Pump-Block-Off-Plate-Type-1-Engines-p/fuel-pump-block-off-cast.htm _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
anthracitedub Samba Member
Posted: Sat Oct 20, 2018 1:21 pm Post subject: Re: Home-made fuel pump rebuilding jig |
Just wanted to share my jig I made from some plastic I had laying around. It already had a hole centered in it so I just played off that. Set a pin in the middle at 13mm and tapped two 8x1.25mm studs in it.
Clamps nicely in my hobby vice. |
Posted: Sat Oct 20, 2018 3:27 pm Post subject: Re: Home-made fuel pump rebuilding jig |
^^ That's slick
I have an original jig and find I don't use it. I prefer my bench vise. I put a punch in it 13MM above, push the body down to pull the diaphragm into position and tighten the 6 screws. Much faster. _________________ Contact me at [email protected]
Posted: Sat Oct 20, 2018 3:54 pm Post subject: Re: Home-made fuel pump rebuilding jig |
Yeah, I usually put them together without a jig... getting ready to build a few and came across this thread. I thought I’d whip one up with what I had laying around and try it out. I took apart one pump and it’s missing a small reed/check valve and the small retainer plate/screw... so I gotta find those pieces before I can play. |
Posted: Sat Oct 20, 2018 7:17 pm Post subject: Re: Home-made fuel pump rebuilding jig |
anthracitedub wrote: |
If you need the reed valve and retainer, PM me. I have tons and can drop one in the mail. _________________ Contact me at [email protected]
sweden Samba Member
Posted: Tue May 14, 2019 8:51 am Post subject: Re: Home-made fuel pump rebuilding jig |
This is how my fueltool look like. Took 5 minutes to make and have been used for many years.
M10 thread in the bakelite and in with a screw of right length.
_________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
T3 TriStar airride with Audi 1,8T engine and Porsche 996 gearbox. |
kevincoupnj Samba Member
Joined: December 22, 2019 Posts: 4 Location: South Carolina
Posted: Thu Feb 11, 2021 10:55 am Post subject: Re: Home-made fuel pump rebuilding jig |
I just rebuilt an original pierburg fuel pump for my 1967 bug. Thanks to all for the info on the preload requirement and jig. I found it easy to assemble the fuel pump, leaving the upper housing screws loose enough allow the diaphragm to move. After setting the preload on the bench jig, which will pull the diaphragm into the lower housing, you can tighten the screws. |
64bugg Samba Member
Posted: Tue Oct 26, 2021 9:26 pm Post subject: Re: Home-made fuel pump rebuilding jig |
Just to add to this thread for a 36hp pump at tdc the plunger is at the correct 35mm hieght so no tool needed. Also it put my ww diaphram at a relaxed fit so easy top install with it on the motor. It will be awhile before i can run it on my new build but anxious to see where my fuel pressure falls. |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Wed Oct 27, 2021 6:48 am Post subject: Re: Home-made fuel pump rebuilding jig |
That Poster in the back round has my 57 Oval from the 1992 Kelly Park Show. Oh yeah nice tool also...
