LHG Samba Moderator
Joined: April 13, 2000 Posts: 1855 Location: LostHillsGuy, CA
Posted: Wed Apr 06, 2005 9:17 am Post subject: Covering Walk Thru Bulkheads |
I have a 65 walk thru deluxe. I want to cover the partition behind the front seats but don't have anything to work off of. There are some photos around but if anyone has some that show more detail that would be a great help. Specifically, where are the seams, and how much is covered on the panel behind the seat?
Thanks
This a photo from Sewfine that shows the walk thru bulkhead area in question.
_________________ Brian O'Kelly
Central Coast Chapter, CA - Vintage Volkswagen Club of America
www.centralcoastvwclub.com
www.facebook.com/groups/vintagevwclub/ |
Stanagon Samba Member
Joined: July 11, 2003 Posts: 4186 Location: Boston, MA
Posted: Wed Apr 06, 2005 10:00 am Post subject: |
I'm not exactly sure from your post what you are looking for.
I stripped all the interior panels from a '67 Standard walk-thru last year. I'll include a picture below that shows the original walk-thru bulkhead panels compared to some reproduction ones. The original panels have been sold and I have the repros listed for sale here. I could take some dimensions from the repros if that helps.
LHG Samba Moderator
Posted: Wed Apr 06, 2005 10:04 am Post subject: |
I am talking about the material that covers the metal partition behing the two front seats. Not the walk thru panels that screw to the partition.
Thanks _________________ Brian O'Kelly
Posted: Wed Apr 06, 2005 10:31 am Post subject: |
OK, now I know what you mean.
This is the only picture I have in my files that shows the bulkhead panels removed but the material still on the bulkhead. Maybe it will help.
I pulled the material off the passenger side bulkhead but it didn't all come off in one piece. I still have a fairly large chunk of it and would be happy to let you borrow it if it would help. I did not try to pull the material off the driver's side. Send me a pm with your address if you want me to send the piece that I have left.
-Stan |
Posted: Wed Apr 06, 2005 10:41 am Post subject: |
Here's another picture that I found which might help.
In this picture I have already stripped off the upper part of the upholstery from the passenger side bulkhead. You can see the white paint on the upper part of the bulkhead. Upholstery still remains on the rest of the passenger side bulkhead and is complete on the driver's side bulkhead. |
Lind Samba Member
Joined: November 06, 2000 Posts: 9913 Location: idaho
Posted: Wed Apr 06, 2005 11:00 am Post subject: |
this picture kind of shows it. the seam is near the middle of the transition. I can take better photos in a few weeks.
_________________ .
Wanted:
LHG Samba Moderator
Posted: Wed Apr 06, 2005 11:09 am Post subject: |
I can see the seam on the curve. I also found a pic that shows a seam also going down the front that angles.
I see in the above photos it only wraps around and inch or two on top and doesn't cover the whole front side of the partition. Is that correct? I can't tell how much it wraps on the side. The same couple of inches?
Is it three pieces on each side?
Oh heck, any upholsteres out there with a patten _________________ Brian O'Kelly
Posted: Wed Apr 06, 2005 11:33 am Post subject: |
When I was trying to pull it off, it certainly seemed like it was all one piece. I think there is a major seam on the inside top corner that tore away easily. I'll take a look at the piece I salvaged tonight and see if it might help.
-Stan |
Yustrn JHC Controla
Joined: August 01, 2000 Posts: 5478 Location: Ovaland, CA
LHG wrote: |
Oh heck, any upholsteres out there with a patten |
Why don't you just ask Lenny at WCC? I'd send you pics of mine, but I'm gone till May...wanna wait? _________________ I own a copy of "The Car of the Century" by Garwood. This means I am authorized to act like a twat in thesamba forums. |
Posted: Wed Apr 06, 2005 7:48 pm Post subject: |
The piece I have shows how the three seperate pieces come together pretty well.
This shows the top inner corner of the piece behind the passenger seat.
You can really see how it works on the backside.
Send me a pm if you want to borrow this piece or have me send higher res. photos as e-mail attachments.
-Stan |
LHG Samba Moderator
velvetgreen Samba Member
Posted: Thu Apr 07, 2005 5:55 am Post subject: |
i had the same question about my 65 walk thru bus. TMI is repopping salt n peppa but no one seems to be repopping the vinyl that goes over top of the bulkhead. I discovered mine were missing after i re pop rivetter the OG panels back in place. oh joy.. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Thu Apr 07, 2005 10:52 pm Post subject: Re: Covering Walk Thru Bulkheads |
LHG wrote: |
Thanks
That's my bus there.
Sewfine has all this info on hand, and did a very workmanlike job.
As close to original as any I've seen.
Here's some other pix also taken before I detailed the dashboard:
_________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Fri Apr 08, 2005 8:38 am Post subject: |
LHG,
The scrap piece of upholstery I have is on it's way to you. You'll be able to tell a lot from it. Just return it when you are done. It looks like they used at least three pieces and the top layer is folded over about a 1/4 inch at the stitched seams.
Nice bus there J.dot, Sewfine does nice interiors. They did some seat covers for my Vanagon Westy several years ago that have held up well and still look good after 5 years.
-Stan |
LHG Samba Moderator
Posted: Fri Apr 08, 2005 8:56 am Post subject: |
Mr Pickens, while searching for photos of a finished bulkhead, I came across yours on the Sewfine website. I've been using that set for reference. Between the photos of yours, and the stuff Stan has supplied, my upholsterer buddy say he can do it. Thanks _________________ Brian O'Kelly
rjonas Samba Member
Joined: July 24, 2004 Posts: 644 Location: Chandler, AZ
Posted: Sat Jan 05, 2013 3:26 pm Post subject: |
Getting ready to wrap the bulkhead vinyl on my 65 walk thru deluxe and I'm looking for some more detailed pictures of this sewn vinyl, location of seams on tubing, the juntion of the 3 pcs in the corner behind the seat and behind the rivited on panel and where it terminates at the "B" pillars.
OG material pictures preferred...I'd love to check out an original interior W/T bus in person...anyone in the Phoenix, AZ area down for a visit?
Thanks,
Roy _________________ 1979 Type-2 Westfalia “Sandy”
1973 Type-181 Thing "Velma"
1956 Type-1 Beetle Patina Project “Rosie”
www.azbusclub.org |
zehbeh Samba Member
Joined: February 16, 2008 Posts: 249 Location: Stuttgart
Posted: Mon Jan 07, 2013 1:23 am Post subject: |
Here are some pictures of my original drivers side bulkhead cover.
If you need more pictures, let me know, I still have them.
Right side is different in length and angle.
Christian
rjonas Samba Member
Posted: Mon Jan 07, 2013 8:37 am Post subject: |
Those are perfect! Thank you.
It appears the vinyl is just cut flush at the "B" pillars with no sewn edge at all where the blukhead rail meets the headliner material?
Same at the bottoms of the triangle panel where it terminates under the walk thru side panel rubber. _________________ 1979 Type-2 Westfalia “Sandy”
www.azbusclub.org |
Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1154 Location: San Tan Valley, Arizona
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Mon Jan 07, 2013 3:27 pm Post subject: |
Someone in the Dakota's was reproducing the pre sewn sections within the last year or two. Perhaps Everett coulde assist in finding the member? I tried a couple of different searches but came up empty. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
