travisrowland Samba Member
Joined: February 29, 2004 Posts: 29 Location: Chandler, Az
Posted: Fri Apr 15, 2005 11:06 am Post subject: Accelerator Pump |
What are the signs, sounds, and symptoms of needing to adjust my Accelerator pump? I have a 34 pict-3 with a .009 dizzy running electonic points. When at idle, it will be smooth for a few seconds, then bottom out and pick itself back up. When I get in it and then slow down quickly, it wants to stall out, I tap the gas once and it will even itself back out. Could this be an accelerator pump issue? _________________ Travis C. Rowland Sr
TYPE 1
1962 Rag Top
1641dp |
L-jetronic Samba Member
Joined: March 26, 2004 Posts: 168 Location: San Diego, CA
Posted: Fri Apr 15, 2005 12:10 pm Post subject: |
Symptoms of a bad accelerator pump will surface when you attempt to ACCELERATE...Meaning when you try to suddenly pick up speed, you open the throttle, but don't get get good squirt of RAW gas. Similar symptoms if the tube just isn't simply pointed straight down the carb. Try looking down the carb w/engine off, air cleaner removed, and pull the accelerator cable all the way quickly to open throttle. You should see (and smell) a squirt of raw gas from the tube pointing down into your carb. Good Luck. _________________ Where Have All the Horses Gone?
DER SPELLING WERDS
63 sold as a 64, November 1963
Daily driver, 29 miles/gallon!!
SD, EC, OB. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Apr 15, 2005 6:13 pm Post subject: Re: Accelerator Pump |
Hi Travis,
Do a full tune up on the engine. Then go to type2.com and get the tune up proceedure from the library there for your carb.
Eric&Barb |
Kaferfiend Samba Member
Joined: August 15, 2004 Posts: 439 Location: Selah WA
Posted: Fri Apr 15, 2005 6:39 pm Post subject: Re: Accelerator Pump |
travisrowland wrote: |
What are the signs, sounds, and symptoms of needing to adjust my Accelerator pump? I have a 34 pict-3 with a .009 dizzy running electonic points. When at idle, it will be smooth for a few seconds, then bottom out and pick itself back up. When I get in it and then slow down quickly, it wants to stall out, I tap the gas once and it will even itself back out. Could this be an accelerator pump issue? |
Sounds like it could be a float valve issue. How do the plugs look? I agree on the do a full tune up. Replace eveything you can, and do everything to the book. The problem should cease to be.
-kf |
Posted: Fri Apr 15, 2005 8:24 pm Post subject: It is all for nothing now |
Well, I did all that, drove around the block and it was stuttering, parked it to make an adjustment, and noticed that all the oil was pouring out on the driveway. I turned it off grabbed a beer and fought the tears. Looks like it is all going to come out now. I am so frustrated I decided that I am going to do a full rebuild, slowly and methodicly. Thanks for the advice though _________________ Travis C. Rowland Sr
TYPE 1
1962 Rag Top
1641dp |
Posted: Fri Apr 15, 2005 8:44 pm Post subject: Re: It is all for nothing now |
Hi Travis,
Darn! Sorry to hear that. Oil cooler and FW seal leaks or even just blown out, can be caused by stuck oil pressure relief valve/s and/or incorrect relief springs, and/or too big of oil pump, and/or too thick of oil, and/or too much oil in the crank case. Would suggest fixing oil leaks again and examine oil cooler for swelled condition, if swelled replace. Then before starting the engine again install oil temp and pressure gauges. Oil pressure above 80 PSI is to be avoided!
We had an engine rebuilt by a very good shop. Installed the gauge senders and found at start up oil pressure too high and had to RPM is carefully to avoid 80 PSI limit. After fifteen minutes in 70 F weather at 3,000 RPM lowest oil pressure was 60 PSI. Turned out rear relief valve spring was aftermarket stiffer one!!
Eric&Barb |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Sat Oct 20, 2018 12:46 pm Post subject: |
L-jetronic wrote: |
Symptoms of a bad accelerator pump will surface when you attempt to ACCELERATE...Meaning when you try to suddenly pick up speed, you open the throttle, but don't get get good squirt of RAW gas. Similar symptoms if the tube just isn't simply pointed straight down the carb. Try looking down the carb w/engine off, air cleaner removed, and pull the accelerator cable all the way quickly to open throttle. You should see (and smell) a squirt of raw gas from the tube pointing down into your carb. Good Luck. |
I realize this discussion is for a 34 PICT but are the accel pump tubes for this carb and the 28 the same? I ask because mine goes out straight over the carb opening but doesn't go down into it. Should it go down or does the 28 have a different shaped accel pump tube?
I am trying to determine which way it should face. One person said straight over the butterfly. Another said something else. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
KTPhil Samba Member
