Ghia Sapphire Radio
joe comfort
joe comfort is offline
PostPosted: Mon Apr 18, 2005 5:55 pm    Post subject: Ghia Sapphire Radio Reply with quote
Which AM/FM Sapphire 12 volt radio is correct for the 1967 Karmann Ghia?
Thanks!
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Apr 18, 2005 6:29 pm    Post subject: Re: Ghia Sapphire Radio Reply with quote
Thanks!
Hi Joe,
At the dealership when purchasing the VW, it would be a Sapphire IV. Later whenever the owner got around to buying one.......
Eric&Barb
joe comfort
PostPosted: Mon Apr 18, 2005 9:03 pm    Post subject: Re: Ghia Sapphire Radio Reply with quote
Hi Eric and Barb, I found a web site from the forum that lists all radios and specifies year and car model. According to the site the IV model is for a Ghia but is 6 volt. The site says i needa VI, model 7fbvg. Who knows!
GhiaNut
GhiaNut is offline
PostPosted: Tue Apr 19, 2005 6:45 am    Post subject: Reply with quote
Sapphire V or Blaupunkt Frankfurt.
YellowSplittie
YellowSplittie is offline
PostPosted: Tue Apr 19, 2005 10:53 am    Post subject: Reply with quote
Sapphire VI. 12V AM/FM for 67.
The IV is a 6V model from 1966.
The V is AM only.
morrd1
morrd1 is offline
PostPosted: Mon Oct 27, 2014 1:07 pm    Post subject: Reply with quote
Hello,
Just want confirm - Sapphire I, it was in Ghia 64 in original ?
Regards
Matt
1964 Karmann Ghia
http://www.thesamba.com/vw/forum/viewtopic.php?t=584324
https://www.facebook.com/ProjectGhia64
BulliBill
BulliBill is offline
PostPosted: Mon Oct 27, 2014 2:19 pm    Post subject: Reply with quote
The V is AM only.
I'm pretty sure that a Sapphire V is an AM/FM 12 volt radio... monaural too I think. When I get home I'll double check the ones I have.
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
mfitzsimor
mfitzsimor is offline
PostPosted: Tue Oct 28, 2014 10:26 am    Post subject: Reply with quote
Sapphire V is 12v AM. Sapphire VI is 12v AM/FM. Both were 1967 only models.
From notes I copied from somewhere on the internet for the Sapphire VI:
"This is probably the most sought-after of all the the Sapphire models. It’s a one-year-only, 12 volt, AM/FM mono radio making it desirable for many VW years. As far as I can tell it was made only by Bendix but there were two models, one with a pair of output transistors above the shafts like the IV (7FMBV) and a later version with a combined pair above the on/off shaft. (7FMBVX) To get technical, the change was from NPN to PNP transistors and because the combined transistor pair is NLA I’ve been able to repair a 7FMBVX with separate NPN transistors. This model also used the black and chrome faceplate and the rubber knobs."
I have one in my 1969. I suspect it was not dealer installed, but added later in the car's life.
portland, or
69 cypress green ghia coupe
82 vanagon TD
86 quantum syncro
