KSims1868 Samba Member
Joined: February 04, 2004 Posts: 813 Location: Houston
Posted: Tue May 03, 2005 10:06 am Post subject: Bamboo parcel tray install |
I have one of those Bamboo Parcel Trays. It came with the "L-brackets" and sheet metal screws to install it.
My question - do you just screw it into the body with these, or is there a way to mount it that doesn't require screwing these new holes into the metal body?
Also - do you just screw it up into the bamboo tray frame and then into the body - allowing the bracket to be seen underneath, or has anyone screwed the bracket into the body 1st (upside down) and then screwed it into the parcel tray to hide the bracket behind the tray?
Am I over-complicating this? _________________ HAC - Houston Air Coolers
1956 Oval Bug
*played out look!!
I like Fast Cars, Young Women, and Easy Money --- Funny --- Bugs seem to get me NONE of this! |
volks67beetle Samba Member
Joined: April 16, 2004 Posts: 916 Location: Sturbridge, MA
Posted: Tue May 03, 2005 12:34 pm Post subject: |
Thanks, but that isn't on my bamboo tray.
I could attach something like that somehow though...thanks for the idea. _________________ HAC - Houston Air Coolers
1956 Oval Bug
*played out look!!
Kel Dub Samba Member
Joined: February 04, 2004 Posts: 809 Location: Long Beach, CA
Posted: Tue May 03, 2005 1:41 pm Post subject: |
I have the two L brackets screwed directly into the body metal and a zip tie going around the steering collum and holding the tray up. The zip tie is about halfway down my steering collum attaches near the rear frame of the tray, hardly noticeable. The L brackets just arnt strong enough to hold the tray, not the wolfsburg west one atleast. |
Kais Collection vintage treasures
Joined: February 18, 2005 Posts: 1570 Location: Rotterdam, The Netherlands
Posted: Tue May 03, 2005 2:37 pm Post subject: |
I did it like this.
Took 2 pieces of aluminum (one for each side), drilled 2 holes in each and put the bolts in. By twisting the bolts you can make the rack sit tight. The rack rests on the lower bolt. Can use a shorter upper bolt, but didn't have it lying around. And just like Kel Dub I used a zip tie going around the steering collum and holding the tray up.
Good luck! _________________ Insta: @kaiscollectionvt
Fb: @KaisCollectionVT
Please check my ads: https://www.thesamba.com/vw/classifieds/search.php?username=Kais+Collection
Kai's Collection - vintage treasures |
jonassunshine Samba Member
Posted: Sat Mar 06, 2021 7:28 pm Post subject: Re: Bamboo parcel tray install |
Mine for the bus and the bug neither came with any brackets or screws I think I'll just use bailing wire and duct tape |
lhd65bug Samba Member
Joined: September 04, 2020 Posts: 49 Location: United Kingdom
Posted: Sun Mar 07, 2021 3:32 pm Post subject: Re: Bamboo parcel tray install |
I secured my bamboo parcel shelf in my '67 bug without brackets by applying sellf-adhesive velcro tape on the edges and wedging it place. The velcro hook fabric adheres to the interior carpet. As long as you don't keep heavy objects on it, it will be fine (at least mine is). |
nreslifer Samba Member
Posted: Sun Mar 07, 2021 5:32 pm Post subject: Re: Bamboo parcel tray install |
I just let the sides rest on the side like in the photo and used a zip tie around the steering column to hold the front of tray up and forward works ok.Really wanted to avoid drilling any holes for the sides.
EODTECH* Samba Member
Posted: Sat May 01, 2021 2:30 pm Post subject: Re: Bamboo parcel tray install |
Mine is the tray that just has the brackets weaved in w/the bamboo, and came with 2 screws. No other hardware. So obviously it's meant to be held in by the pressure from those 2 screws. Problem is...I can't find the screws. Anybody happen to know off hand what SIZE...they are? I guess I could measure the hole and do a hit and miss at Home Depot rifling thru their metric ones... |
c21darrel Samba Member
Murdlem Samba Member
Joined: February 06, 2004 Posts: 512 Location: Port Angeles, Washington
Posted: Tue May 04, 2021 3:16 pm Post subject: Re: Bamboo parcel tray install |
I drilled no holes, and just have a few zip ties where the tray meets up against the car. Unless you are down under the dash looking, it is not noticeable, and no holes. Holds up great. The ties on the trunk release are probably not necessary, but just an extra precaution.
_________________ Eric Meldrum
68 Ghia
Check out my blog. https://vwlifenet.wordpress.com/ |
vwgirl1961a Samba Member
Posted: Fri Aug 20, 2021 1:03 pm Post subject: Re: Bamboo parcel tray install |
I just replaced my old one with a brand new one this morning.
To install it, I used heavy duty twist ties and 2 screw hooks. which I screwed on the top of the frame in the area where it lines up to the steering column. I twisted heavy duty twist ties around the hooks and draped the twist tie over the steering column.
[quote="nreslifer"]I just let the sides rest on the side like in the photo and used a zip tie around the steering column to hold the front of tray up and forward works ok.Really wanted to avoid drilling any holes for the sides.
_________________ "Age doesn't really matter unless you are a cheese". |
gt1953 Samba Member
Posted: Sun Aug 22, 2021 6:52 am Post subject: Re: Bamboo parcel tray install |
The bamboo tray looks nice and fancy but are worthless for me. the do not hold stuff as it fall thru the webbing. I decided to make my own which is more usefull.
_________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Sun Aug 22, 2021 7:37 am Post subject: Re: Bamboo parcel tray install |
That's pretty neat!!!!
gt1953 wrote: |
gt1953 Samba Member
Posted: Sun Aug 22, 2021 5:16 pm Post subject: Re: Bamboo parcel tray install |
The parcel tray is easy to make, the cup/coin holder came from a mid 90's Ford Taurus.
72 type 1
72 Squareback
