cmaydawg Samba Member
Posted: Sat May 07, 2005 2:26 pm Post subject: transaxle codes/ super beetle/ghia compatability |
was curious if anyone knew if a 73 super beetle transaxle had that 3.88 gear? , or if the tranny codes would indicate gearing, and if so where could i find out once i had the code, and finally would it bolt straight into a 70 IRS ghia pan ? thanks for your input. chris |
myb356 Samba Member
Joined: October 14, 2004 Posts: 408 Location: bay area california
Posted: Sat May 07, 2005 9:58 pm Post subject: |
I have a 3:88 in my 70 ghia...the nose cone mount is different and will require the older nosecone to be put on. The 3:88 usually has a single side cover case. The 4:12 usually has two diff side covers. |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Sat May 07, 2005 10:21 pm Post subject: |
Look here on the transmission opposite the fill plug.
http://img93.echo.cx/my.php?image=vwtrans1.jpg
AT coded tranny should have the 3:88 r&p _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
Bruce Samba Member
Posted: Sun May 08, 2005 1:54 am Post subject: |
Like Gary said, you are looking for trans code AT stamped into the case on the lower right side forward of the diff. You will also need to swap the nose cone to be able to mount up to your chassis. When you do this, you have to make sure the new nose cone does not interfere with the cage for the mainshaft ball bearing. Sometimes you have to grind a relief in the nose cone to clear the cage. |
klepic Samba Member
Joined: February 05, 2004 Posts: 61 Location: Snohomish, WA
Posted: Thu Nov 03, 2005 7:19 pm Post subject: |
so is the 3.88 only found in a SSC trans? Is the AT designation only on SSC cases? |
Bruce Samba Member
Posted: Fri Nov 04, 2005 12:24 am Post subject: |
No, there are a few very rare DSC AT gearboxes. Those have all the same internals as a SSC, but with 2 sidecovers. |
fergie61 Samba Member
Posted: Wed Jul 04, 2007 12:10 am Post subject: transaxles |
hey how can i tell the type and year of the transaxle i was told it was an irs but i dont know i got two different numbers i dont know what means what the first is AH3730544 this is stamped into a flat piece and the other is 113.301.103 E and that is just like part of the pouring of the case any help would be awesome |
Bruce Samba Member
Posted: Wed Jul 04, 2007 1:46 am Post subject: |
Well, you already know it is IRS. An AH trans has a 4.12 R&P.
Is there a tube around the input shaft? _________________
