Claire Samba Member
Joined: April 26, 2005 Posts: 596 Location: Cruisin' the Santa Cruz Mountains
Posted: Thu May 12, 2005 12:19 pm Post subject: OK to use Slick 50 or other engine treatment? |
This has probably been discussed before, but I couldn't locate specific information with a search. So please bear with me being a newbie!
I've always used an engine treatment such as Slick 50 or newer brands in all of my cars. I swear by the stuff and have never had engine problems since using it.
But this is my first Bug. ('67) Is it OK to use an engine treatment on an air-cooled engine?
Thanks. _________________ Custom cars need love too!! |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
lesterplimpton64 Samba Floydiyan
Joined: December 08, 2004 Posts: 99 Location: Colorado Springs
Posted: Thu May 12, 2005 1:45 pm Post subject: |
I just use STP. _________________ Piss off Canada |
Kaferfiend Samba Member
Joined: August 15, 2004 Posts: 439 Location: Selah WA
Posted: Thu May 12, 2005 2:30 pm Post subject: Re: OK to use Slick 50 or other engine treatment? |
Claire wrote: |
Thanks. |
You know how it got it's name, right? Whomever sold the first bottle made a Slick $50.
Seriously, I would never let Slick 50 or any other additives even touch my car. Not to mention go IN my engine.
For one, stuff like Slick 50 with Teflon... Teflon or PTFE... which is great on frying pans is NOT good in engines. It's a solid, and remains a solid. It clogs, it doesn't coat.
But, some people love it. I would never use it. Even if it was free.
-kf |
Claire Samba Member
Posted: Thu May 12, 2005 2:42 pm Post subject: |
OK I read through the posts, thanks for the lead. I see there are clearly two camps on this, those for engine treatments and those against. I still have one question-
Is there anything particular about an air-cooled VW engine that different than a typical engine with regards to engine treatments?
For example, if you've got a Ford and a VW and you like engine treatments, you'd put it in both, right? Of would you only put it in your Ford because of something with the VW? _________________ Custom cars need love too!! |
Posted: Thu May 12, 2005 2:53 pm Post subject: |
To update what I said in my posts.... I still use the 'restore' brand in my high milage water cooled rides and so far the few vw's I've added it to ( older engines with miles and see if it helps them run a bit longer before rebuild) seem to be running smooth, less oil consuption and better MPG then before the treatment so I don't think it has hurt them one bit... has it helped, by my personal independent experience I'd say yes. It is a much different product than Slick 50 or the other additives....
I would not add it to an otherwise great running engine expecting it to do anything, this stuff is for engines showing signs of wear not some miracle additive to make an engine last forever. |
Claire Samba Member
Posted: Thu May 12, 2005 3:16 pm Post subject: |
My engine is 10 years old with an unknown amount of miles on it. It was driven with some regularity for the first 5, but the second 5 it was 99% in storage. Thanks for the clarification! _________________ Custom cars need love too!! |
Posted: Thu May 12, 2005 3:35 pm Post subject: |
Claire wrote: |
My engine is 10 years old with an unknown amount of miles on it. It was driven with some regularity for the first 5, but the second 5 it was 99% in storage. Thanks for the clarification! |
I would see if it blows some oil on startup or uses any but does not leak as much as it uses and after a good tune up and with the oil change IMO it is a good candidate for the Restore brand additive... your car, your call.
I don't think it will harm your engine which is what some of the other additives can do with the teflon issue. |
Claire Samba Member
Posted: Thu May 12, 2005 3:51 pm Post subject: |
So far no oil on start up, no leaking. But it's way overdue for an oil change and a tune up, so those will be done ASAP. It's in the shop getting brakes right now. (massive $800 replacement job... they were wasted!) I've used engine treatments in every car I've had since about 1980 and have never had an engine problem with any of them since using an engine treatment. So I'll to do the same with the bug. Thanks, I just wanted to make sure it was OK on these types of engines, since this is my first air-cooled engine.
Now if I could just figure out where to fill the radiator... just kiddin'!! _________________ Custom cars need love too!! |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Claire Samba Member
Posted: Fri May 13, 2005 8:24 am Post subject: |
Bear with me here, I'm a total rookie- What is a Bently? Just in case the entire braking system is shot again. If it can be replaced for $80 instead of $800 I'd definately like to learn what it is! _________________ Custom cars need love too!! |
Flynt55 Samba Member
Joined: March 23, 2003 Posts: 98 Location: Dubuque, Iowa
Posted: Fri May 13, 2005 9:16 am Post subject: |
"bentley" is in reference to the VW official service manual, expensive but well worth the cost.
Chris |
Posted: Fri May 13, 2005 9:22 am Post subject: |
Claire wrote: |
Bear with me here, I'm a total rookie- What is a Bently? Just in case the entire braking system is shot again. If it can be replaced for $80 instead of $800 I'd definately like to learn what it is! |
Claire,
We WILL bear with you! You ask good questions, and you listen to everyone that gives a reply. That's rare. You show concern for your aircooled, and want it to be safe and fun to drive. We have respect for people like you. Therefor, never feel you weighing on anyone here. Keep asking questions! We'll answer the best we can!
-kf |
Claire Samba Member
Posted: Fri May 13, 2005 9:54 am Post subject: |
Gee thanks! Yes, that's exactly what I want to do- get the car to a point where it's safe and fun.
My husband had two bugs eons ago, a '58 and a '65. He used to work on them back then. But a few years ago he had a bout with meningoencephalitis (combination of meningitis and encephalitis which is swelling of both the brain's covering and the brain itself) He lives with constant head pain and its very hard for him to do anything where his head is lowered, such as climbing around under cars!
So between the two of us we can do some of the simple work the car needs, but most jobs will have to go off to a mechanic. Since this car is my baby though, it's up to me to learn all I can about it and make the decisions on what is done on it.
This forum has been a tremendous help. _________________ Custom cars need love too!! |
Posted: Fri May 13, 2005 10:38 am Post subject: |
on my other 67 i just replaced front and rear shoes as rest of brakes were fine. $40 in cost. robert bentley official factory reprint work shop manual is $35 for 66-69...... it can save you lots of money doing repairs yourself. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Fri May 13, 2005 12:43 pm Post subject: |
yeah 800 for brakes sounds way high... even if you were getting all German parts and paying 65 labor I don't see how anyone could hit 800 bucks! |
Claire Samba Member
Posted: Fri May 13, 2005 2:20 pm Post subject: |
Hmmmmmmmm... this is a total replacement including drums, shoes, master cylinder, everything was shot beyond repair. They couldn't resurface the drums it was all warped. The inside of the brakes was filled with sludge and everything a mess, broken and warped.
If $800 is high for a total replacement of everything let me know, I'll go somewhere else next time. Part of the reason we went to this guy is we didn't want to drive it any further than we had to with the brakes mushing to the floorboards! _________________ Custom cars need love too!! |
Claire Samba Member
Posted: Fri May 13, 2005 2:44 pm Post subject: |
Thanks for the link, yeah looking at the price of the parts, it does add up quick! _________________ Custom cars need love too!! |
Herby Samba Member
Joined: January 24, 2005 Posts: 742 Location: LALA Land
Posted: Fri May 13, 2005 2:46 pm Post subject: |
$800 is very high...even for modern cars thats pretty high. I mean maybe if it was everything including brake lines, then maybe...but still sounds high _________________ 62 Beetle
73 Super Beetle German Look project
03 TDI Jetta
Airspeed
www.airspeedvwclub.com
"Do not assume that there isn't room for improvement just because VW didn't do it."
Samba #34091 |
