gatorjos Samba Member
Joined: April 19, 2003 Posts: 406 Location: San Francisco
Posted: Tue May 17, 2005 12:59 pm Post subject: clutch questions |
I got my motor out of my Ghia, so I thought I would replace the clutch. Is it necessary to replace the throwout bearing as well? When I grab the transmission input shaft, I can move it up and down some (like .020" each way). The shaft is of course supported by the gland nut as well, so how important is it anyway?
Also, I've got the pressure plate with the three big springloaded 'claws' on it as opposed to the modern ones. The contact point shows some wear, but I'm not sure if it warrants a replacement. Can I replace it with a modern one like this one?
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D311%2D141%2D025%2DCX
It seems so inexpensive not to just replace the whole shabang. Sure is easy to get to right now.
Thanks,
Jos _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
1972 Ghia cabriolet (full body-off restoration -- stolen after five years of ownership)
2004 Passat 1.8T (manual)
http://21stcenturyhobo.com |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Tue May 17, 2005 1:18 pm Post subject: Re: clutch questions |
gatorjos wrote: |
Thanks,
Jos |
Play in the input shaft like that is normal.. it is supported by the needle bearing in the gland nut when engine is installed.
What year trans do you have... you may need this style PP instead if you have a 70 or earlier
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D311%2D141%2D025%2DEX
And yes I would do everything...get the kit and check the trans mounts while your there... may want to consider pulling the flywheel and do the crank seal and flywheel o-ring too. |
Posted: Tue May 17, 2005 4:21 pm Post subject: |
Thanks, good to hear I can use the new style pressure plate. Are there any brand clutches you guys recommend in thee $50 range? I'm building a solid 1776 to mate to it... _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
