TimberwolfZ28 Samba Member
Joined: May 17, 2005 Posts: 197 Location: Battle Creek, MI
Posted: Wed May 18, 2005 10:38 am Post subject: W-120 or 125 suitable for a 2276 in a light sandrail? |
I was originally thinking I would use a w110 in the 1915, but since I needed a new crank afterall I might as well go big.
I know the 125 might be on the big side, especially for a smaller displacement motor, but I was thinking with the larger motor I have going, it might be better suited.
What do you think? |
BattleShipBus Samba Member
Posted: Wed May 18, 2005 1:33 pm Post subject: |
what ratio of rockers? What carb configuration are you running and what valve sizes? _________________ Andy |
Posted: Wed May 18, 2005 6:35 pm Post subject: |
BattleShipBus wrote: |
what ratio of rockers? What carb configuration are you running and what valve sizes? |
rockers havent been purchased yet. In it's 1915cc configuration, the motor has a single weber 40 DCNF. I keep reading that a single carb is best for off road. BUT, that being said, I am thinking of going EFI for the new motor.
heads I have now are ported 041 with dual springs and only slightly oversized valves. But I am thinking of selling them and buying a set of these from CB:
044 MAGNUM with 40 x 35.5mm S/S valves, Dual Super Rev Springs, Chromoly Retainers, & Sure-Grip Locks (Mahle 94mm bore) |
philip1 Samba Member
Joined: March 11, 2004 Posts: 334 Location: wales, UK
Posted: Thu May 19, 2005 4:23 am Post subject: |
the dcnf a berg special?? and i can tell you now if ya goin off roading then get a diff carb to the dcnf, petrol wit spill out the emulsion tubes wen bouncin round or harsh conering. |
