dmercer Samba Member
Posted: Wed May 18, 2005 10:29 pm Post subject: Repro of the Judson air scoop for Karmann Ghia |
Hullo folks,
I recently did a write up of a reproduction of the Judson air scoop for the Karmann Ghia. If you are interested, you can find it along with images at the following URL:
http://www.8kb.net/scoop/
Best,
D |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Posted: Thu May 19, 2005 4:47 am Post subject: |
Great report Dan...it's always good to have a first hand report on something like this...especially when this repro was being sold with pictures that didn't show enough detail.
Human nature being what it is every seller will want to show their product in a good light so you rarely get pictures showing any shortcomings.
The original Judson Scoops were certainly of a better quality but I'd imagine with a bit of elbow grease you should be able to iron out a few of the repro imperfections.
The problem with having a batch of these scoops repoped is that you need to throw an large amount of cash at the project without having a good idea of how many you'll be able to sell.
We have a member who has offered to repop these in fiberglass but I've resisted as some will resist fibreglass in favour of a cast repop or an original...it's a bit of a conundrum. _________________ John.
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Fri May 20, 2005 11:48 am Post subject: |
So how much was that original one I sold too cheap worth when I sold it too cheap in 93?
And for more abuse... how much would it have been worth in today's market? |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Fri May 20, 2005 11:54 am Post subject: |
two or so years ago, 150-200 was the going price for an original. _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
Posted: Fri May 20, 2005 12:01 pm Post subject: |
Thanks Dave... I knew when posted about abuse I could count on someone like you to chime in! |
Posted: Fri May 20, 2005 12:20 pm Post subject: |
When you consider the Judson Gauge is more readily available but carries a higher price, current prices for scoops aren't THAT bad. Recent price around the $300 mark.
The problem with buying an original scoop is that there aren't enough to go around.
Strange really...rarer than a Judson Gauge but sells for less. I suppose the reason for this is that there are less people bidding on Scoops.
Most people who come to me looking for an OG Scoop usually find one in a year or so. So a small market would exist for a cheap fibreglass repop to use while they look for an OG version.
Perhaps we could use Dan's alloy repop to make a really cheap fibreglass repop. My brain hurts _________________ John.
coad Samba Scapegoat
Posted: Fri May 20, 2005 12:27 pm Post subject: |
John, wasn't someone working on a scheme to re-work a Judson so that it could fit in a Ghia without the need for a scoop? As I recall their solution was rather simple and the results looked original and not hacked.
Any progress on that front? |
Posted: Fri May 20, 2005 1:06 pm Post subject: |
coad wrote: |
The only way you can take height out of a Judson set-up is to modify the intake manifold or to leave off the Judson Aircleaner.
The problem with taking out a piece of the intake manifold is that as you lower the Judson body you fall foul of the Generator and the throttle linkage, the distributor and HT leads. If you're going to do this it's a difficult balancing job.
On another Samba thread this was stated:
Quote: |
The factory spec method to install the 36 Judson on a bus is to modify the intake manifold by taking out a 36.7 mm section just below the carb (now supercharger) mount base, this allows the judson to fit vertically in the engine compartment (from the paperwork that came with the bus). |
That was news to me...the only cutting suggestions I know of made by Judson was for a 4 inch section to be cut from a Bus engine bay ceiling, for the cutting of the Ghia decklid using a Scoop template and a piece of the rain pan on the decklid of a convertable.
Haddon Judson jnr tells me Judson made a few experimental manifolds but didn't market them.
Of course that won't stop a lot of people having a go...if anyone knows how to do it successfully I'd be pleased to hear about it too _________________ John.
nbtim Samba Member
Posted: Fri May 20, 2005 1:49 pm Post subject: |
I'd buy a repop. Sure would be better than the stand-off kit I fabbed. |
Posted: Sat May 21, 2005 9:29 am Post subject: |
The modified manifold idea is what I remember reading about on your website. That would be a much better solution than the scoop for ghias.
I love Judsons, but it would take a lot to make me butcher a decklid to make one fit. |
Posted: Mon May 23, 2005 7:15 am Post subject: |
coad wrote: |
here here, thats why i bought the mag supercharger. _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
Peter_Plade Samba Member
Joined: January 09, 2005 Posts: 551 Location: Denmark
Posted: Thu Jun 30, 2005 2:19 am Post subject: |
Hi does anybody know how you can see
the diffrens between an org and repro scoop?
Peter |
coolairX2 Samba Member
Posted: Thu Jun 30, 2005 4:56 am Post subject: IMO, Thats a real nice repro. |
The surface seems just a touch rougher than an original and the letters are not as crisp. Other than that its a great repro and would fool 99 people out of 100 once painted and on the car.
-Craig |
Posted: Thu Jun 30, 2005 6:37 am Post subject: |
John Moxon wrote: |
Unfortunately Mr. Morley seems to answer emails about this scoop only when it suits him. I carried an ad for these repops, on my site for over 2 years and the ungreatful **** wouldn't even answer me |
I've had the same thing happen to me with him. Its a real hit or miss. He will ignore emails forever. The good news is once you do connect he does follow thru and ship and all that-- it's making that first contact that drives you crazy. |
Posted: Thu Jun 30, 2005 6:58 am Post subject: |
Hm what if I got a scoop where there is no lettering
on the inside? |
