M_atthewanderson Samba Member
Joined: January 25, 2005 Posts: 288 Location: Seattle
Posted: Sun May 29, 2005 5:35 pm Post subject: push rod tube gasket help, help, |
How can you replace the push rod tube gasket without taking the engine out. how about those spring loaded push rod tubes? cut mine off then put those in?
hu?
hu?
matthew anderson _________________ 1980 2.0 Sunroof Vanagon |
vwkess Samba Member
Posted: Sun May 29, 2005 6:26 pm Post subject: |
No need to cut them. Easy to take out without damaging them. I made a simple tool years ago. It's just a threaded rod with a rubber hose pushed on the end of it.
Just take your rocker shaft off and pull out the pushrod. Insert the tool into the pushrod tube and pull out.
I'll post a pic of the tool in the morning... |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Mon May 30, 2005 6:33 am Post subject: |
I don't see what good the spring loaded push rod tubes are, you still have to take the push rods out to change them. It takes a good ten seconds to remove the tube once the rod is out. Just get new seals from bus depot and change what you have. The hardest part is making sure you put the stuff back together the way it was. The long retaining spring can be a pain, but otherwise it's pretty easy. _________________ My Art:
http://www.instagram.com/flynn8552/ |
Posted: Mon May 30, 2005 6:58 am Post subject: |
The trick is to use a set of vice-grips, set them so they are tight enough to grip the tube without crushing it, then start wiggling it around till you break the seal, once you break the seal they should come right out. This is for aircooled which is what Matt has. I don't know nufin about no waterboxers _________________ My Art:
