justmike Samba Member
Posted: Tue May 31, 2005 12:40 pm Post subject: Performance ECU Chips |
Does anybody know if they work in 1988 2.1 L? Is there actually a performance benefit? Could it cause problems in the long run? |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3327 Location: Talos IV, Piedmont Arizona
Posted: Wed Jun 01, 2005 5:42 am Post subject: |
my understanding is these things fool the brain into thinking it's cold therefore running a fat(rich)mix. _________________ If You Build It______It Will Run
1959 Panel bus, 1966 Single cab. 73' 181. 73 Westy. 91' H6 Vanagon 3.3L.
.....................All Current....................... |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1881 Location: Montreal
Posted: Wed Jun 01, 2005 7:31 am Post subject: |
I believe you need a specific ECU 022D, aircooled.net sells the chip and has the info. |
DanJReed Samba Member
Joined: July 30, 2004 Posts: 548 Location: Riverton NJ
Posted: Wed Jun 01, 2005 7:58 am Post subject: |
Its a little more than tricking it into running rich, that's easy to do with a resisitor, and often the "ebay scam".
A true chip will change the mapping of the injector timing, spark timing, and in turn give it a little more boost in some power ranges and remove the stock rev limiter. In most modern cars this can be changed on the fly with a laptop, but not in our old Vannies... _________________ -Dan
(87 Westy Vanagon, 98 Jetta GLS 2.0, 95 Golf Sport) |
jtroll333 Samba Member
Posted: Thu Jun 09, 2005 11:43 am Post subject: |
I seen the little e-bay trick and then also seen a computer upgrade for $50.00 and has anyone ran one of those off e-bay? |
