getset Samba Member
Joined: March 07, 2005 Posts: 437 Location: PNW | OLY
Posted: Tue May 31, 2005 5:31 pm Post subject: New syncro new problems |
So I recently bought an 87 syncro on ebay. After owning it for 3 weeks I have already put 2000 miles on it, and haven't really had any problems other than the oil pressure light buzzing at me after I exit off the freeway. however upon returning from my most recent trip I noticed a slight hesitation, and then it wouldn't start. After letting it sit for a day it fired right up. I guess it was tired. There is however an odd fluid dripping off the coil. It is not oil, and feels like brake or power steering fluid. I am having difficulty determining the source of the leak. When I have the vehicle running I can see fluid dripping from the coil, but not being sprayed into that region. Is there a hose that is hidden from view that I am missing? I have had a few people take a quick look to try and determine the source with no luck. I am almost about to take it to a mechanic.
Thanks |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Tue May 31, 2005 5:47 pm Post subject: |
Coils have fluid inside them. Are you sure it's not from the coil itself? |
DanJReed Samba Member
Joined: July 30, 2004 Posts: 548 Location: Riverton NJ
Posted: Tue May 31, 2005 7:31 pm Post subject: |
Yes, coils are filled with oil to cool them.
The oil is very toxic. Filled with PCBs.
Remove and replace the coil - should fix it. _________________ -Dan
(87 Westy Vanagon, 98 Jetta GLS 2.0, 95 Golf Sport) |
getset Samba Member
Posted: Tue May 31, 2005 7:57 pm Post subject: |
I thought that was what it was, but I have never heard of one leaking.
I will replace it tomorrow. Thanks! |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue May 31, 2005 11:53 pm Post subject: |
jgobel wrote: |
For some reason, leaking coils on Vanagons are quite common. Make sure you get the right coil- Bosch blues don't cut it for Vanagon ign. systems. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Jun 01, 2005 5:16 am Post subject: |
Its common, or so your the 2nd person to say so.
My guess is that its due to its location, its too hot down there! _________________ -Dan
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Wed Jun 01, 2005 6:11 am Post subject: |
My Bosch blue coil works well, but then I'm aircooled and should have points. _________________ My Art:
http://www.instagram.com/flynn8552/ |
Posted: Wed Jun 01, 2005 10:25 am Post subject: |
mightyart wrote: |
My Bosch blue coil works well, but then I'm aircooled and should have points. |
California aircooleds had Hall senders from late 1978. I should have specified water cooled Vanagons. My bad. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
walrus Samba Member
Joined: June 02, 2005 Posts: 507 Location: ashland ky
Posted: Sat Jun 04, 2005 1:03 am Post subject: |
I just replaced a pool pump startup capacitor(I borrowed it from a friends nonfunctioning heatpump). I found out when they leak they are bad. |
