schlanks70vdub Samba Member
Posted: Wed Jun 01, 2005 2:47 pm Post subject: Brake adjustment problem |
i've got new brake pads, new slave cylinders on all four tires. I've gone around all the wheels and tighted the shoes just until they rub the drums.. now the problem i'm having is, on the left front tire... I screw it down till it slightly rubs the drum then i reach up.. press on the brake pedal, then go back down and spin the wheel again only to find out that the shoes aren't hitting the drum anymore. Is there a bad slave cylinder? or something else that i'm overlooking..
thanks in advance... |
NAES Samba Member
Joined: September 10, 2003 Posts: 2121 Location: AREA-52 Southern Killafornia
Posted: Wed Jun 01, 2005 3:05 pm Post subject: |
new shoes and wheel cylinders (not slave) are only the beginning. There are soft lines that should probably be replaced and then you need to make triple sure that everything is tight.
Bleed, bleed, bleed forever until you are absolutely positive there is no air in the lines. Air is my first guess. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
rizzag Now Wut?
Joined: April 19, 2001 Posts: 3116 Location: Keizer, OR
Posted: Wed Jun 01, 2005 3:06 pm Post subject: |
try adjusting it some more now, maybe the shoes were just not centered and now they are.
when i adjust brakes i adjust them out as hard as i can to be sure they are centered then i back them off slightly till i can spind the wheel with slight drag. _________________ flossin, tossin, dippin, and trippin |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Wed Jun 01, 2005 3:13 pm Post subject: |
After you adjust them drive around the block and do it again, make sure your hoses are good also.
What year bus, do you have the right hardware, did you put the springs on right. Are the shoes seated in the wheel cylinder. _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
angus_hanger Samba Member
Joined: July 20, 2002 Posts: 139 Location: Pinole, CA
Posted: Wed Jun 01, 2005 4:07 pm Post subject: |
NAES wrote: |
Bleed, bleed, bleed forever until you are absolutely positive there is no air in the lines. Air is my first guess. |
I'm with NAES ... collapsed or air in the lines would be my guess.
Cheers!
Lancer _________________ His - 'Rosie' - '64 Westy
Hers - '66 Beetle
SST '04 -'06
"Why yes sir, Sheriff, I do like Fat Chicks." |
Buckly Samba Member
Joined: September 14, 2004 Posts: 1030 Location: Spokane, WA
Posted: Wed Jun 01, 2005 5:17 pm Post subject: |
When it rains it pours. I'm having to do abunch of brake work right now on a few VWs, a couple guys on a Thing email thread are having brake problems. I was driving merrily along today and noticed some sponginess developing in the brakes, after a few blocks the brakes were gone, thank the cosmos for e-brake. somehow the left front bleeder had come loose. I hadn't touched my brakes since last summer.
Anyway, I'd agree with previous posts, bad soft line, air , and when adjusting get them as tight as you can and back them off.
good luck, and let us know what you find. _________________ Cool runnins,
_______________________
Bucky |
Saggs Samba Member
Joined: December 23, 2003 Posts: 662 Location: Lincolnton, NC
Posted: Wed Jun 01, 2005 6:22 pm Post subject: |
My 67 had a right front wheel that would brake hard then stick like crazy. Turned out to be a collapsed rubber line. It would let the fluid be pumped thru it but it wouldn't let it back out. Works great, i'm gonna change the rears just in case also. _________________ "One man can make a difference...Jesus did." |
Posted: Thu Jun 02, 2005 7:19 am Post subject: Problem solved!! thanks everyone. |
I can now stop with no problem. It was two things.. I tightened the shoes to the drums and backed off till they just grazed the drum. Then I went around and blead the brakes and YEP there was still air in the lines. I will however replace the soft lines ASAP but for now I was driving it around my neighborhood and came to a stop sign. I'm still restoring the bus so all the seats and everything else are just pilled in the back... well, I hit the brakes and the bus STOPPED everything flew forward including me haha so the work great..... BTW someone asked what year... it's a 67... 13window... Thanks again for the help
Shane.... |
