63 vwnotch Samba Member
Joined: December 31, 2002 Posts: 734 Location: Riverside,CA Econo Motors
Posted: Thu Jun 09, 2005 9:16 pm Post subject: Pop outs and the VW Classic ? |
I've been away for quite some time now, since i've been back home I've spent a couple hours a week trying to get my car together enough for the classic. Just noodling an hour here and there.
The only rubber left that isnt new is my popouts, i have seals both inner and outer, but have yet to attempt to take them apart.
Is this as simple as it looks or is it a little tricky?
I ask cuz my og's arent in the worst condition, but are bad enough to be replaced, but i can live with it till after the classic, as i dont intend to win anything i just want to hang w/ my car.
odds and ends left to go, but im scramblin.
cya @ the classic,
rob _________________ BUS WANTED: 13 window BUS any year considered.. |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Thu Jun 09, 2005 10:49 pm Post subject: |
It's really not that hard to replace, I suggest you soak any screws with some penetrating oil over night to loosen them.
Once you have the window apart I suggest you do a deep cleaning of the frame and parts if needed.
Put the inner rubber around the glass then put the frame around it, use some silicon spray it makes it slide together real nice.
The outer piece will take alittle patience, look for the seam and put them in the same place on both sides (I don't know were is correct but I put mine in the middle of the hinge area) If you lay them out in the sun they work alittle better.
To put it in I use a hard plastic tool designed for window repairs, but you should be able to make one with a toothbrush or something similar, just shave it down so you can poke the rubber in. _________________ It's not about the window, it's about the people.
German Folks |
Zarana-X Samba Dreadnok
Joined: September 03, 2004 Posts: 372 Location: How could hell be any worse?
Posted: Fri Jun 10, 2005 5:43 am Post subject: |
The frames are a bitch to get apart if the screws are stuck. If the inner seals are pretty good, I'd let them be.
The outer seal isn't too bad, just time consuming. I used WD-40 and a tool made from a sharpened popsicle stick to put them in. _________________ "In order to create, you have to destroy." |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Fri Jun 10, 2005 10:40 am Post subject: |
Please dont forget my bumper or good original seat material as promised in our deal. Jack or Everett and Im sure others that know me at the Classic will be more than happy to take my bumper back and or the rear seat material as per our deal. Or $75 value for the bumper as I stated the day I brought it to your house. Thanks again, let me know.
Jason Weigel _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
