Rumdum Samba Member
Posted: Thu Jun 16, 2005 7:27 pm Post subject: What do you home-sandblasters use for silica protection? |
I've been reading, trying to learn as much about sand blasting as I can before purchasing one. See that many people are buying them from harbor freight and they dont offer a respirator rated for silica. What are you guys doing for protection??? And where, if any, did you get it? Just curious. Would hate to know that I have prided myself as a nonsmoker for 36 years just to end up with lung cancer from blasting my bus. Though I must say, if the bus turns out really nice it might be worth it.....nahhh... _________________ 1975 Westfalia Campmobile
CB Performance Dual IDF Weber 40
- jetted and optimized by Aircooled.net |
Ed Ruth Samba Member
Joined: May 14, 2005 Posts: 343 Location: Bakersfield, California
Posted: Fri Jun 17, 2005 3:00 am Post subject: Gas mask 3m plus organic vapor cartridge |
Get yourself a full face mask equipped with organic vapor cartridges. A nice one is available from 3M. An internet search revealed this web site for me: http://www.professionalequipment.com/xq/ASP/ProductID.2344/id.8/subID.131/qx/default.htm
Since you will also be using paints, solvents, and acids in rebuilding the van, you will need an organic vapor cartridge. Masks that just cover the nose and mouth disregard the fact that organic vapors can be absorbed by the eyes...and to a lesser extent skin.
The 3M mask is nice and comfortable. I use it when blasting and it keeps all the stuff out of my eyes and lungs. Don't forget...the friction of sanding produces heat which frees organic vapors from solids. Cheers, Ed |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Fri Jun 17, 2005 6:34 am Post subject: |
this one won't do? (i assumed it would, since sand blasting just creates dust, which is a larger particle than paint fumes)
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=44113
i've been using it while sanding and sandblasting (haven't done too much blasting, maybe start using my hobbyair respirator for that if i am wrong to use the convienent face mask _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Jowlz The Anti-Purist
Joined: May 02, 2005 Posts: 2464 Location: Tunkhannock, PA
Posted: Fri Jun 17, 2005 4:23 pm Post subject: |
I've always just used a painting respirator. There are different kinds of sand available for blasting. I usually use black beauty if stripping a frame. It's very aggressive but low dust. _________________ The honey-do list put my project on hold....... |
js99nielsen Samba Member
Joined: August 12, 2002 Posts: 109 Location: Battle Ground, WA
Posted: Sun Jun 26, 2005 9:09 pm Post subject: |
I've done quite a bit of blasting with silica sand and just used an organic vapor respirator but It really doesn't work (note the black snot that still comes out of your nose). Personally I think the best think to do is to NOT use silica sand! I've switched to a product called starbrite and have been very happy with it. It cleans better than the sand, is all uniform size, is not too expensive ($5/50lbs retail price), and it won't (so they say) cause cancer, fibrosis or that stuff. Just my 2 cents. _________________ '50 Tempo Matador (VW powered)
'57 DKW Schnellaster
'58 DKW Schnellaster
'65 dove blue doublecab
'89 Porsche 911 Carrera Targa ROW
'67 #1 SO-42 pearl white poptop walkthru...sold, shoulda kept
'63 beige gray/swr 15 window deluxe...sold, shoulda kept
'67 #2 SO-42 pearl white poptop walkthru...sold, shoulda kept
'67 #3 SO-42 pearl white poptop walkthru...sold, shoulda kept
'64 turquoise kombi...100% original, O rust...sold, shoulda kept |
Posted: Thu Jun 30, 2005 7:26 am Post subject: |
i just looked at my media and i guess i have been using aluminum oxide...about $20 for 50lbs...with the above mentioned respirator...no black snot in my nose...i use the same mask for sanding and get the same clean snot results... _________________ Wish List:
Mark Laken
Fort Collins, CO |
dirtylawnchair Samba Member
Joined: January 26, 2004 Posts: 1234 Location: Bradenton FL
Posted: Thu Jun 30, 2005 4:04 pm Post subject: |
I just bought a sand blaster and am wondering where you guys buy your media/sand. I bought some sand from homecheapo and am not happy with the results. _________________ Paulie
63 Standard OG paint |
DHUFFMAN Samba Member
Posted: Sat Jul 09, 2005 9:24 pm Post subject: |
I to would like to know where to buy media for a sand blaster? |
