tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Wed Jun 22, 2005 5:25 pm Post subject: Anyone have a dead Pertronix? |
.. or Compufire or Accufire that they haven't thrown out yet? I've been tinkering with the "Vanagon" electronic ignition and an old T3 D-jet distributor and I think the ring-with-magnets part might help me with aligning all the bits. |
vdubman71 Samba Member
Posted: Thu Jun 23, 2005 11:35 am Post subject: |
Im not clear n your question, but there isnt really any alignment necessary with a compufire. Occasionally they do short out though. Try a set of points and if they work, your electronic ignition is the problem. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Thu Jun 23, 2005 1:17 pm Post subject: |
Speaking of dead Pertronix I was watching Full Throttle on the History Channel and the challenge this week was to remove the old 1500cc engine from two '67 beetles and replace them with two Scat 2165cc engines with webers and drag them.
Apart for all the incorrect information and other boners in the show, both teams fried their 009 "performance" distributors by wiring up the coil backwards which friend the Pertronix. Both teams were forced to use the "inefficient" factory vacuum distributor or so they said. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
Sylvester Samba Member
Joined: April 18, 2004 Posts: 409 Location: The South
Posted: Thu Jun 23, 2005 1:40 pm Post subject: Heh |
Did they pitch the "crummy" Kadrons and install those hot Webers? Heh _________________ 1971 Westfalia "Samantha"
1600cc "Hun engine"
Oct. 22, 1929. 8:30 pm. The ship is making water fast. We have turned around and headed for Milwaukee. Pumps are working, but sea gate is bent in and can't keep the water out. Flicker is flooded. Seas are tremendous. Things look bad. Crew roll is about the same as last payday. A.R. Sadon, Purser. |
Schmooey Samba Member
Joined: October 19, 2004 Posts: 838 Location: San Diego
Posted: Thu Jun 23, 2005 2:14 pm Post subject: |
I saw that dumbass show, and when each team salvaged the dizzys from the old engines, the winning bug had a stock dizzy, and the loser (I think) had a mech advance unit. It appeared to have no biscuit.
In any case, the show was lame. The guys were too amped up on ego to read the Pertronix instructions.
"Which wire goes where? oh well, I'll just try this way..." _________________ I don't got no steenking cell phone. |
Posted: Thu Jun 23, 2005 3:11 pm Post subject: |
[email protected] wrote: |
What I'm doing is trying to put the factory electronic ignition guts from a watercooled Vanagon distributor into the D-jetronix dizzy from my Fastback. Took a lot of work. The Vanagon shutter wheel for the sensor is the last thing to get in there, and I need to enlarge the hole in the middle to slip it over the existing lobe that the points use. If I had one of the magnetic rings from a Compufire or Pertronix, I could use the hole in that as a template and more easily get the size & shape that I need.
I refuse to put a Pertronix or Compufire in my cars; the one time I tried one I was left stranded, and when I worked in auto parts I saw seven or eight that were DOA .. out of 12 sold before we gave up & quit carrying 'em. |
rsorak Samba Member
Posted: Thu Jun 23, 2005 3:58 pm Post subject: |
I've had a pertronix on a Ford for several years and an accufire on my bus and both have been problem-free so far from day 1. In both I have the stock points in the glove box. _________________ Rick '71 Westfalia & '73 Thing |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Thu Jun 23, 2005 8:39 pm Post subject: |
rsorak wrote: |
I've had a pertronix on a Ford for several years and an accufire on my bus and both have been problem-free so far from day 1. In both I have the stock points in the glove box. |
And the minute you take those points out is when the units will fail.
Tristessa: PM me your addy. I'll send you the ring. I had another samba member send me his failed Pertronix and I don't need the ring to dissect the module itself. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Thu Jun 23, 2005 10:38 pm Post subject: |
PM sent. Thank you for assisting my insanity. |
