briceb Samba Member
Joined: June 21, 2004 Posts: 11 Location: Wildomar, CA
Posted: Wed Jul 06, 2005 7:19 am Post subject: Why does my Dune Buggy body tilt? |
I recently purchased a 71' pan that I had shortened and a 2" lift kit added. When I put the body back on the pan (for the first time) I get this wierd tilt to the back of the body. It is 2-3" higher on one side than the other! How do I fix this? Is there an adjustment that can be made to the torsion/springs? The body is NOT warped as I had it on an older pan before and it looked great (no tilt).
Motor sits level and the front end of the buggy looks good!
Thanx a bunch! |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Wed Jul 06, 2005 7:33 am Post subject: |
quick check: get out a tape measure and measure the distance between the swingplates and the otp of the shock towers on each side. if there is a difference, there is your problem: time to re-index the torsion bars. if the measurements are the same, then you have some pan/body twist. Sometimes a body will develop some twist/sag when moved from one pan to another, or it may have been tweaked to fit the old pan which was a little out of square, so now you have to 're-tweak' it to fit the new pan.
sometimes it is as simple as adding some washers/shims, spacers under the body.
Did you bolt it down to the body mounts on the rear shock towers? if so, did you use rubber pads on both sides? _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
