Tomswesty Samba Member
Joined: July 06, 2005 Posts: 194 Location: Moscow, ID
Posted: Fri Jul 15, 2005 5:07 am Post subject: 87 Westy AC upgrade |
I just had a quick question about the AC hose parts being different from the old SD510 and the SD709. Do you know of a parts place (other than dealer) that might carry the new hose #2 and #4 as shown in Bentley page 87.16? Already have a new dryer. Also how many other surprises should I expect?
Thanks |
weinerwagen Samba Member
Joined: May 10, 2004 Posts: 1548 Location: Monterey, CA -Laguna Seca--Coats, Kansas
Posted: Fri Jul 15, 2005 5:53 am Post subject: |
I just did a swap from the 510 to the 709
make sure you get a unit that has the bolt hole on the back which allows that bracket to hold the hoses in place....
my 84 pump would not work on a 87 _________________ Retired attorney--Tort King. |
r39o Samba Polizei
Posted: Fri Jul 15, 2005 8:45 am Post subject: |
Does that 7 plunger pump work better than the 5, that you can notice.???
You using R134 or R12?
I understand the last vans had a bigger evaporator or is it condensor? Wonder if you can mix and match those items into an earlier van, especially like my 85 Westy???? I don't want to pull new A/C lines in though.
Actually, although less efficent, I would think the rare (dealer installed) front dash mounted A/C would be far more useful in a Westy than that big box that is in the back. I don't need the back of my head cooled, I want the A/C to hit me square in the frontal (lobe) parts. |
Posted: Fri Jul 15, 2005 12:45 pm Post subject: |
I'll let you know if the 7 pumps better than the 5. The 5 arrived DOA with the van so I have nothting to compare that's why I am changing it out. I am with you, I don't want the back of my head cool either but right now I'll take what I can get. It's tooooooo hot to run with open windows only. |
r39o Samba Polizei
Posted: Fri Jul 15, 2005 2:06 pm Post subject: |
r39o wrote: |
You using R134 or R12? |
Posted: Fri Jul 15, 2005 4:23 pm Post subject: |
R134a, to far to drive to Mexico. So will keep you posted. |
Posted: Sun Jul 17, 2005 6:28 am Post subject: |
Got the 709 in yesterday, hooked up the lines (VW wants $270 for those two new sections of pipe) charged it up and it was blowing 49 while 89 outside. Much better than the 89 and 89 I had before. I think the old 510 was dead and needed to be replaced. I don't have to wear a jacket inside but the back of my head feels better. |
Posted: Sun Jul 17, 2005 7:01 am Post subject: |
I use a mixture of R-134 and Enviro-Safe Refrigerant.... _________________ Retired attorney--Tort King. |
