jberger Samba Member
Posted: Fri Jul 15, 2005 7:25 pm Post subject: Cam End Play |
Hi all,
Am I reading the bently correctly that the cam shaft end play should be .0016 to .0051? They refer to axial play. Mine is measuring .015 Maybe I found my mysterious clacking. The cam has 11000 miles on a regrind and new bearings. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Fri Jul 15, 2005 11:24 pm Post subject: Re: Cam End Play |
jberger wrote: |
Am I reading the bently correctly that the cam shaft end play should be .0016 to .0051? They refer to axial play. |
Yep, that's the endplay spec. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
germansupplyscott Samba Member
Posted: Sat Jul 16, 2005 5:51 am Post subject: |
the endplay is controlled by the thrust bearing. depending on where you are at with this (engine apart or not) you can try new bearings and re-measure. i suggest double-thrusting the bearings no matter what. _________________ SL |
Posted: Sat Jul 16, 2005 8:48 am Post subject: |
Thanks ^ I guess it's time to tear it down. A chance to try a different cam profile this time. A blessing? Or a curse? |
Posted: Sat Jul 16, 2005 10:50 am Post subject: |
germansupplyscott wrote: |
i suggest double-thrusting the bearings no matter what. |
Which means buying 3 sets? _________________ '78 Westfalia CDN
'76 Doublecab
Posted: Sat Jul 16, 2005 12:29 pm Post subject: |
just two sets. there is one thrust bearing in each set, and you double up on that one. some vendors sell double-thrust sets but i have not been able to find them at the wholesale level for type 4 engine. _________________ SL |
Posted: Mon Jul 18, 2005 8:24 am Post subject: |
So the question comes up, what cam to use. Does anyone have experience with the Web cam mild hydro? Toying with the idea of switching to solid lifters as I have had horrible luck with the quality of the hydros out there. |
