Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Tue Jul 26, 2005 2:33 pm Post subject: Oil line/ header..how close is too close? |
Split bus with full flowed 1904. Remote filter mounted near left bumper bracket. The oil lines are within an inch or two from the header. Am I asking for trouble? Would braided line make any difference? Even if the lines will hold up, any opinions on heat transfer? Thanks |
kakarottt Samba Member
Joined: December 05, 2003 Posts: 719 Location: Hazard county, Maryland
Posted: Tue Jul 26, 2005 2:37 pm Post subject: |
maybe some exhaust wrap could help? |
Posted: Tue Jul 26, 2005 2:55 pm Post subject: |
I had that same thought. Will probably try it just to be safe. I was hoping someone had some personal success/ horror stories I could learn from. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
Posted: Tue Jul 26, 2005 3:04 pm Post subject: |
I've got no problem with bradied line.
_________________ Glenn
Member #1009
#BlueSquare |
truckersmike Elder Sambanite
Joined: March 16, 2001 Posts: 2025 Location: Bellingham, WA
Posted: Tue Jul 26, 2005 4:44 pm Post subject: |
I use hydraulic lines going inbetween the upper and lower header pipes. They don't touch but have never had any heat damage. These lines are heat resistant and handle like 10k psi. They are tough and much cheaper then most high quality lines. About $20-25 a line. _________________ 59 DD panel. Former Romano's TV delivery bus
67 Westy SO-42 pop-t |
Posted: Tue Jul 26, 2005 7:19 pm Post subject: |
Is that something you can buy by the foot? What kind of fittings does that need? _________________ Tim |
67sleeper Samba Member
Joined: April 19, 2004 Posts: 62 Location: uncharted desert isle
Posted: Tue Jul 26, 2005 8:36 pm Post subject: |
get some of that "Firebraid" from aircooled.net .. its sold be the foot and helps out some temp wise..every bit helps. And also this insulating sheath helps from scraping up the header coating etc. by the braided lines.
http://img.photobucket.com/albums/v609/zatoichi02/pics/close02.jpg |
bugnut68 Samba Member
Joined: June 10, 2003 Posts: 4180 Location: Eugene, OR
Posted: Tue Jul 26, 2005 8:55 pm Post subject: |
I second Glenn's assertion...I've got a Berg full flow kit on my 1776 with stainless braided lines and they come close to the header/Jtube junction but no burns or holes or scratches after nearly 2K miles...oil temps aren't hurting either. |
Posted: Wed Jul 27, 2005 2:17 pm Post subject: |
Gonna try the braided hose. It seems to be the simplest solution and easiest to get.
These forums are great! It's almost as fun as wrenching on the bus. _________________ Tim |
quattlebum Samba Member
Joined: February 06, 2005 Posts: 585 Location: Sacramento,CA
Posted: Wed Jul 27, 2005 2:51 pm Post subject: |
I have the OBERG cleaner with the steel braided lines... no issues at all... |
Posted: Wed Jul 27, 2005 3:04 pm Post subject: |
Krustybus wrote: |
Is that something you can buy by the foot? What kind of fittings does that need? |
My hydraulic line was sold by the foot. The fittings are separate and costs very depending on what kind you want. I decided to get two lines made with a solid fitting on one side and a swivel on the other. The swivels were any dollars more so I opted to just get them on one end so I can install them.
1/2" hose is what I used and I think they put on 3/8" fittings. _________________ 59 DD panel. Former Romano's TV delivery bus
